Ir para o conteúdo principal
How to Restore Synthetic Wig Quality
O que você precisa
  1. How to Restore Synthetic Wig Quality, How to Restore Synthetic Wig Quality: passo 1, imagem 1 %32
    • Fill your container of choice with warm to hot water (enough to cover the entire wig).
  2. How to Restore Synthetic Wig Quality: passo 2, imagem 1 %32
    • To make sure your wig is fully moisturized, add shampoo before and after putting the synthetic wig in the container.
    • Apply the hair shampoo of your choice into the container.
    • If using a bottle with a pump, apply 5-7 pumps of shampoo to the water. If using a squeeze bottle, count to 5 seconds while pouring shampoo into the water.
    • Mix shampoo into the water thoroughly.
  3. How to Restore Synthetic Wig Quality: passo 3, imagem 1 %32 How to Restore Synthetic Wig Quality: passo 3, imagem 2 %32
    • Place the synthetic wig into the container
    • Make sure the wig is completely under water.
  4. How to Restore Synthetic Wig Quality: passo 4, imagem 1 %32 How to Restore Synthetic Wig Quality: passo 4, imagem 2 %32
    • If using a bottle with a pump, apply 5-7 pumps of shampoo to the water. If using a squeeze bottle, count to 5 (seconds) while pouring shampoo into the water.
    • Mix shampoo into the water to clean and moisturize the wig thoroughly.
    • Leave the synthetic wig in the container for 15-20 minutes. The longer you leave it in, the softer your wig will be.
  5. How to Restore Synthetic Wig Quality: passo 5, imagem 1 %32 How to Restore Synthetic Wig Quality: passo 5, imagem 2 %32 How to Restore Synthetic Wig Quality: passo 5, imagem 3 %32
    • Rinse the shampoo from the synthetic wig with warm water from the bottom to the top.
  6. How to Restore Synthetic Wig Quality: passo 6, imagem 1 %32
    • Comb or brush through your synthetic wig to remove knots and tangles, from the bottom to the top.
    • For straight hair synthetic wigs: you can use a small-tooth comb or hair detangler brush.
    • For wavy to loose curl synthetic wigs: you can use a wide-tooth comb or hair detangler brush.
    • There should be no restriction after a full comb or brush through.
  7. How to Restore Synthetic Wig Quality: passo 7, imagem 1 %32
    • Dump the old water from the container and fill it with fresh, warm to hot water.
  8. How to Restore Synthetic Wig Quality: passo 8, imagem 1 %32 How to Restore Synthetic Wig Quality: passo 8, imagem 2 %32 How to Restore Synthetic Wig Quality: passo 8, imagem 3 %32
    • Add the synthetic wig back into the fresh water in your container. Apply the hair conditioner of your choice into the container.
    • To make sure your wig is fully moisturized, add conditioner before and after putting the synthetic wig in the container.
    • If using Silicon Mix, apply 2-3 spoonfuls into the water.
    • If using a bottle with a pump, apply 5-7 pumps of conditioner to the water.
    • If using a squeeze bottle, count to 5 (seconds) while pouring the conditioner into the water.
    • Mix conditioner into the water to moisturize the wig thoroughly.
    • Leave the synthetic wig in the container for 20-30 minutes. The longer you leave it in, the softer your wig will be.
  9. How to Restore Synthetic Wig Quality: passo 9, imagem 1 %32 How to Restore Synthetic Wig Quality: passo 9, imagem 2 %32
    • Rinse the conditioner or Silicon Mix from the wig with warm water from the bottom to the top.
    • Ring out excess water from your wig.
    • Do one last comb or brush through to make sure there are no more tangles or knots in the wig.
    • Pat dry with a soft microfiber towel.
  10. How to Restore Synthetic Wig Quality: passo 10, imagem 1 %32 How to Restore Synthetic Wig Quality: passo 10, imagem 2 %32 How to Restore Synthetic Wig Quality: passo 10, imagem 3 %32
    • Apply the wig to the mannequin head.
    • Using pins can keep the wig secure through the drying process.
    • Leave wig on the mannequin head to dry for one day.
    • For immediate use of wig, dry with hair dryer on medium to low heat.
    • For straight hair synthetic wigs: dry it normally.
    • For synthetic wigs with wavy to loose curls: the curl pattern should return after drying. For more security, add curlers to the hair, following the curl pattern, while drying.
  11. How to Restore Synthetic Wig Quality: passo 11, imagem 1 %32
    • After the drying process, your synthetic wig should look good as new!
    • For maximum shine and hold, add hair spray after drying.
    • For straight synthetic wigs: if you are experiencing any small hairs that are sticking out after the drying process, use a flat iron on medium to high heat.
    • For wavy or loose curl synthetic wigs: if you are experiencing any small hairs that are sticking out after the drying process, use a curling iron (or flat iron) on medium to high heat and follow the curl pattern of the wig.
  12. How to Restore Synthetic Wig Quality: passo 12, imagem 1 %32
    • Before
  13. How to Restore Synthetic Wig Quality: passo 13, imagem 1 %32
    • After
Linha de Chegada
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 28
Últimos 30 dias: 86
Duração total: 3,652
