Ir para o conteúdo principal
How to Restore An Expo Marker
O que você precisa
  1. How to Restore  An Expo Marker, How to Restore  An Expo Marker: passo 1, imagem 1 %32
    • Collect all of the markers you want to restore.
    • Obtain isopropyl alcohol (rubbing alcohol) or vinegar.
  2. How to Restore  An Expo Marker: passo 2, imagem 1 %32
    • Pour a small amount of either alcohol or vinegar into a small bowl, using enough to cover the tip of the markers.
    • Soak the tip of the markers in the alcohol or vinegar until the ink comes out of the tip of the marker.
    • In some cases, you will see the ink of the marker swirl out.
  3. How to Restore  An Expo Marker: passo 3, imagem 1 %32 How to Restore  An Expo Marker: passo 3, imagem 2 %32
    • Place the cap back on the marker.
    • Let the marker sit tip side up for at least 24 hours. The alcohol should penetrate inside the tip of the marker.
  4. How to Restore  An Expo Marker: passo 4, imagem 1 %32
    • Your marker should be good to go.
    • If your marker is not functioning properly, it may be a sign that your marker dried out completely.
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 62
Últimos 7 dias: 522
Últimos 30 dias: 2,020
Duração total: 26,622
