Ir para o conteúdo principal
How to Reshape a Warped Nail Polish Brush
O que você precisa
  1. How to Reshape a Warped Nail Polish Brush, How to Reshape a Warped Nail Polish Brush: passo 1, imagem 1 %32 How to Reshape a Warped Nail Polish Brush, How to Reshape a Warped Nail Polish Brush: passo 1, imagem 2 %32
    • Remove the nail polish brush from bottle.
    • Wrap the bottle of nail polish with aluminum foil to prevent the polish from drying.
  2. How to Reshape a Warped Nail Polish Brush: passo 2, imagem 1 %32 How to Reshape a Warped Nail Polish Brush: passo 2, imagem 2 %32
    • Wipe the brush clean with a paper towel.
  3. How to Reshape a Warped Nail Polish Brush: passo 3, imagem 1 %32 How to Reshape a Warped Nail Polish Brush: passo 3, imagem 2 %32
    • Clean the brush in small amount of 100% pure acetone in a glass bowl.
    • DO NOT USE ANY OTHER TYPE OF CONTAINER MATERIALS OTHER THAN GLASS or PORCELAIN FOR ACETONE. Acetone is a chemical that will damage the plastic’s surface by softening it, smearing it, or even dissolving the plastic.
  4. How to Reshape a Warped Nail Polish Brush: passo 4, imagem 1 %32
    • Blow-dry the brush on medium-low heat from brush base to tip for 30-90 seconds.
  5. How to Reshape a Warped Nail Polish Brush: passo 5, imagem 1 %32 How to Reshape a Warped Nail Polish Brush: passo 5, imagem 2 %32 How to Reshape a Warped Nail Polish Brush: passo 5, imagem 3 %32
    • Reshape the warm bristles by hand or press in a book, rotating as needed.
    • You can reheat the bristles if they are not yet flattened into the desired shape.
Conclusão
Test a swatch on a piece of paper to check the shape of the brush with the nail polish. If the shape is not yet to its desired form, restart the guide to reshape the brush.
Michelle Nguyen
Membro desde: 09/28/22
121 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 77
Duração total: 593
