Ir para o conteúdo principal
How to Reset Your Schlage Connect to Factory Settings
O que você precisa
  1. How to Reset Your Schlage Connect to Factory Settings, How to Reset Your Schlage Connect to Factory Settings: passo 1, imagem 1 %32
    • Ensure the latch is retracted (not locked).
  2. How to Reset Your Schlage Connect to Factory Settings: passo 2, imagem 1 %32
    • Remove the battery cover by sliding the cover upwards.
  3. How to Reset Your Schlage Connect to Factory Settings: passo 3, imagem 1 %32 How to Reset Your Schlage Connect to Factory Settings: passo 3, imagem 2 %32
    • Using a Phillips #0 screwdriver, remove the bottom screw and top screw.
  4. How to Reset Your Schlage Connect to Factory Settings: passo 4, imagem 1 %32
    • Carefully remove the device from the door.
  5. How to Reset Your Schlage Connect to Factory Settings: passo 5, imagem 1 %32
    • Locate the programming code behind the alarm device.
    • You will need the original factory's preset user code (listed on the back of the device) for Step 12.
  6. How to Reset Your Schlage Connect to Factory Settings: passo 6, imagem 1 %32 How to Reset Your Schlage Connect to Factory Settings: passo 6, imagem 2 %32 How to Reset Your Schlage Connect to Factory Settings: passo 6, imagem 3 %32
    • Reattach the alarm device to the door by screwing the bottom and top screws.
  7. How to Reset Your Schlage Connect to Factory Settings: passo 7, imagem 1 %32
    • Disconnect the battery.
  8. How to Reset Your Schlage Connect to Factory Settings: passo 8, imagem 1 %32
    • Discharge residual electricity by pressing the exterior Schlage button three times on the keypad.
    • Performing this step ensures that any residual electricity left in the battery is removed.
  9. How to Reset Your Schlage Connect to Factory Settings: passo 9, imagem 1 %32 How to Reset Your Schlage Connect to Factory Settings: passo 9, imagem 2 %32 How to Reset Your Schlage Connect to Factory Settings: passo 9, imagem 3 %32
    • Press the Schlage button and continue pressing while at the same time reconnecting the battery.
    • You should see three green check marks on the lock's face.
  10. How to Reset Your Schlage Connect to Factory Settings: passo 10, imagem 1 %32 How to Reset Your Schlage Connect to Factory Settings: passo 10, imagem 2 %32
    • Release the button and reattach the battery cover.
  11. How to Reset Your Schlage Connect to Factory Settings: passo 11, imagem 1 %32
    • Complete the reset procedure by pressing the Schlage button one time.
  12. How to Reset Your Schlage Connect to Factory Settings: passo 12, imagem 1 %32
    • Enter the original factory's preset user code on the keypad.
    • The bolt will move, and the process is complete once the bolt stops moving.
Linha de Chegada
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 15
Últimos 30 dias: 42
Duração total: 1,146
