Introdução
If you have forgotten Password, PIN, if you want to erase or refresh your tablet, you can do reset your tablet from the Troubleshoot menu.
Warning! A reset returns Surface to its factory settings!
Vídeo de Apresentação
Connect the charger.
Select "Ease of Access".
Open "On-Screen Keyboard".
Select:
Troubleshoot
Reset your PC
Bei TrakStore ist nur “Neustarten” möglich. Das Tablet arbeitet dann aber genauso, wie als würde “Reset” angezeigt. Deutsche Spracheinstellung.
I want to reset the color in this tablet now please
Set the color in this tablet please
What if I get to this point and my laptop freezes and won't allow me to go any further?
Follow instructions on the screen to reset your tablet.
Did you ever get an answer to your tablet issue?
This method didn't work it still asks for the password before allowing you to reset or restore… what else you got?
Has anyone figured out how to get past step 4? My touchscreen wont let me select next or cancel. I've tried to use a keyboard and same results. ???????
Exaxtly the same happend to me…..I-ONIK TW-8
Geh -
Additional free space is needed on the drive where windows is installed. Free up some space and try again.
What should I do now please help?
This will reset and restore your tablet to its factory settings.
That's all.
Did you do it successfully?
Thank you so much!! I’ve been scouring the internet trying to reset my POS Walmart tablet and this is what finally worked!
Mine seems to get stuck on step 4 I have the 2 options run and close but they are blanked out cannot go any further
I am too experiencing the same problem with my Asus tablet. Have you managed to fix it? I also need help.
Me too with my acre tablet
But I don't want to loose my data (like photos & other files). Please suggest.
thanks alot is working
Displayed after restarting after trouble shooting said PC was shut down incorrect and said something about firm ware and a windows kwy
Hi there, Can you help me to fix my tablet-pc?
I reseted it one time but as it was supposed to install Windows, it keeps on rebooting again & again no change in the installation.
Wow thanks that was easy
I get stuck on “additional space is needed where Windows installed.”
I forgot my password and i reinstall new windows 10 and my touch, volume,and the camera are not working again please I need help thanks
Mine ends up with instructions warning of clearing a trust area and asks me to either press F12 or Esc or volume up and down buttons But no method for input?
Merci infiniment
Thank you too :)
ZFix -
Merci pour tout
Néanmoins moi j'ai tablette pc winpad 10 après réinitialisation ça s'est arrêté à 66% ce qui bloque l'allumage du tablette a nouveau.
Comment il faut procéder pour récupérer ma tablette
Did not work on ROTOR tablet (without integrated keyboard) - at some point the crap tablet entered EFI shell - and does not react on external keyboard. Now - stuck in EFI shell. Only wanted to restore original windows setting, as one of the windows updates resulted in a non-working on-screen-keyboard (and also refusing external keyboard) after logging in...
34 outras pessoas executaram este guia.
25 comentários
thankz for help
Hi, did you know how to fix Windows tablet stuck in boot? It said that “no bootable device found “. Tablet brand and model : Vulcan Journey.
It started after I erase/format the tablet because I forgot the password.
Thanks
Hello. I have a MPMan with Win 10 installed and the touchscreen does not work anymore.
I'm going to install win 8.1 on it .... win 8.1 was out of production. thank you very much
while i am reset final step erase everything touch not in work how to fix?
having same problom touch doesent qwork at reset part
lachjul -
iam using linx its good
I I appreciated it helps very well thanks
I get to step 4 but the buttons are blank and i can go no further
Hi, am using speedstar windows tablet after reseting the screen didn’t touch and windows cannot be loaded, what can i do.
ekaso
Hello to everyone,
Me to it stock at reinstall your pc, cannot press next.
I HAVE A WINDOW DUST, DIJ4100BK132..
If anybody as a solution or another technique to do. PLEASE.
Thank you.
I followed the instructions to restore my linx tablet to factory settings but a blue screen came up with a bar code what do i do now
My avgo tablet has gone to auto repair and I am trying to reset it to its factory . the problem to it is that it needs to be reinstalled to its windows 10 and i bought a 32gb memory stick in order to store backup , so i can use the usb to transfer the files to my avgo. what else can i do its getting frustrated.
Hello, do u no how to reset the Tablet pc model no: "TL10IE2" Intel education solutions
Merci mec du fond du coeur.???
Buongiorno ho un tablet dell' Windows ma c'è la password di un altra persona come faccio per fare un mio account nuovo
How do I reset the westgate resort pivot tablet? I've tried to manually hard factory reset but it still doesn't work or just freezes on the start up screen
bonjour
merci pour le tuto, j etais bloqué sur un mot de passe oublié ,le votre m a permis de remettre mon petit ordi
en fonctionnement
encore merci
When I reset, the device prompts "Additional free space is needed where Windows is installed. Free up some space and try again"
Any ideas on how to bypass this issue?
wow c est très magnifique
