Ir para o conteúdo principal
How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla
O que você precisa
  1. How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla, Wiper Arm: passo 1, imagem 1 %32 How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla, Wiper Arm: passo 1, imagem 2 %32
    • Take the tip of your flathead screwdriver, and wedge it underneath the wiper cap.
    • Firmly pry the wiper cap upwards until it's completely off.
  2. How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: passo 2, imagem 1 %32 How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: passo 2, imagem 2 %32
    • Place the head of your ratchet on the exposed nut.
    • Loosen the nut by turning your ratchet counter clockwise.
  3. How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: passo 3, imagem 1 %32 How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: passo 3, imagem 2 %32
    • Once the nut is loose enough, you may grab it and place it to the side.
  4. How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: passo 4, imagem 1 %32 How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: passo 4, imagem 2 %32
    • Firmly grip the lower end of the wiper arm.
    • Pull it towards you, so that the wiper arm is extended in the upward position.
  5. How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: passo 5, imagem 1 %32 How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: passo 5, imagem 2 %32
    • While holding the lower end of the wiper arm, tug the wiper arm upwards until completely detached.
    • Don't be discouraged if the wiper arm isn't detached right away. You may have to tug upwards a few times to detach it.
  6. How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: passo 6, imagem 1 %32 How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: passo 6, imagem 2 %32
    • Have your new wiper arm extended in the upward position (just how your old wiper arm was extended at the end of Step 4).
    • Take your wiper arm, and center its hole on the exposed metal threading.
  7. How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: passo 7, imagem 1 %32 How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: passo 7, imagem 2 %32
    • Once the wiper arm has been placed onto the metal threading, firmly grip the lower end of the wiper arm.
    • Slowly push the wiper arm downwards and away from you, so that it's flat with the windshield.
    • Make sure to do this slowly so that your fingers are not compressed by the wiper arm and the windshield.
  8. How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: passo 8, imagem 1 %32 How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: passo 8, imagem 2 %32 How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: passo 8, imagem 3 %32
    • Place the same nut from earlier onto the exposed threaded metal.
    • Place the head of your ratchet onto the nut.
    • Tighten the nut by turning your ratchet clockwise, until it can no longer be tightened.
  9. How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: passo 9, imagem 1 %32 How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: passo 9, imagem 2 %32 How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: passo 9, imagem 3 %32
    • Firmly press the wiper cap upon the exposed nut.
    • Once the wiper cap is secure, you may repeat steps 1-9 to the other wiper arm.
Conclusão
Once you have replaced one of your wiper arms, repeat the same process for the remaining wiper arm.
4 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 15-2, Green Fall 2015 Membro de Cal Poly, Team 15-2, Green Fall 2015
CPSU-GREEN-F15S15G2
Membros da 4
Autoria de 4 guias
Um comentário
good merci
thank you
Moad Mezzari - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 16
Últimos 30 dias: 69
Duração total: 9,459
