Ir para o conteúdo principal
How to Replace the Wheels on an Office Chair
O que você precisa
  1. How to Replace the Wheels on an Office Chair, Removing Casters: passo 1, imagem 1 %32
    • Lay the chair down.
    • If the chair is too heavy to turn upside down, have someone help you do it.
  2. How to Replace the Wheels on an Office Chair: passo 2, imagem 1 %32
    • Wipe the stem of the caster with a rag or paper towel to remove any dust or debris.
  3. How to Replace the Wheels on an Office Chair: passo 3, imagem 1 %32 How to Replace the Wheels on an Office Chair: passo 3, imagem 2 %32 How to Replace the Wheels on an Office Chair: passo 3, imagem 3 %32
    • Use a flathead screwdriver in between the caster and the base of the chair to pry the wheel out of the socket.
    • Turn the screwdriver gently until the caster starts to move upwards away from the chair.
    • Try rotating the screwdriver at different angles if the caster won't come out.
  4. How to Replace the Wheels on an Office Chair: passo 4, imagem 1 %32 How to Replace the Wheels on an Office Chair: passo 4, imagem 2 %32 How to Replace the Wheels on an Office Chair: passo 4, imagem 3 %32
    • Use a prying tool that is big enough to fit between the caster and over the stem.
    • Gently pull on the caster upwards and it should come off.
  5. How to Replace the Wheels on an Office Chair: passo 5, imagem 1 %32 How to Replace the Wheels on an Office Chair: passo 5, imagem 2 %32
    • Measure the wheel's height and length.
    • Once you've done that, purchase your new casters.
    • Large casters(about 3"), are more durable and versatile. Twin-wheel casters are usually used in office settings.
  6. How to Replace the Wheels on an Office Chair: passo 6, imagem 1 %32 How to Replace the Wheels on an Office Chair: passo 6, imagem 2 %32
    • Push the caster's stem into the bottom of chair leg.
    • Install the new casters.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Ismail Dhorre
Membro desde: 01/10/21
160 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 44
Ao todo: 6,715
