Ir para o conteúdo principal
How to Replace the Suction Cups for the Anti-Clamp
  1. How to Replace the Suction Cups for the Anti-Clamp, Suction cup information: passo 1, imagem 1 %32 How to Replace the Suction Cups for the Anti-Clamp, Suction cup information: passo 1, imagem 2 %32
    • The suction cups are secured to the clamp by friction-fit pins.
    • To remove the pins, you have to push them through their indents in the clamp's arms.
  2. How to Replace the Suction Cups for the Anti-Clamp, Remove the suction cups: passo 2, imagem 1 %32 How to Replace the Suction Cups for the Anti-Clamp, Remove the suction cups: passo 2, imagem 2 %32 How to Replace the Suction Cups for the Anti-Clamp, Remove the suction cups: passo 2, imagem 3 %32
    Ferramenta utilizada neste passo:
    Clampy - Anti-Clamp
    $24.95
    • Rotate the suction cup towards the indentation in the clamp's arm to release the pin.
    • You may need to use significant force and another hand to support the Anti-Clamp.
    • Remove the suction cup and its pin.
    • During reassembly, angle the pin into the hole across from the indent before pushing it back into the arm.
  3. How to Replace the Suction Cups for the Anti-Clamp, Remove the pin: passo 3, imagem 1 %32 How to Replace the Suction Cups for the Anti-Clamp, Remove the pin: passo 3, imagem 2 %32 How to Replace the Suction Cups for the Anti-Clamp, Remove the pin: passo 3, imagem 3 %32
    • Pull the pin through the top of the suction cup and remove it.
Conclusão
For other general electronics skills guides, click here.
Alex Diaz-Kokaisl
Membro desde: 01/16/22
213.664 Reputação
Autoria de 1.040 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.656 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 41
Ao todo: 1,187
