Ir para o conteúdo principal
How to Replace the Net on a Basketball Hoop
O que você precisa
  1. How to Replace the Net on a Basketball Hoop, Net: passo 1, imagem 1 %32
    • Set up a ladder below the basketball rim.
    • Make sure the ladder is steady and placed on a level surface.
  2. How to Replace the Net on a Basketball Hoop: passo 2, imagem 1 %32 How to Replace the Net on a Basketball Hoop: passo 2, imagem 2 %32 How to Replace the Net on a Basketball Hoop: passo 2, imagem 3 %32
    • Loop the first net loop through the basketball rim.
    • Push the net through each loop on the basketball rim.
    • Pull the net loop down and spread the rope across the rim coil as shown
    • Pull the net tightly to the rim.
  3. How to Replace the Net on a Basketball Hoop: passo 3, imagem 1 %32
    • Using the same technique from step 2, loop the remaining net loops around the rim.
  4. How to Replace the Net on a Basketball Hoop: passo 4, imagem 1 %32
    • Test the net and remove any wrinkles by pulling down on the bottom of the net.
  5. How to Replace the Net on a Basketball Hoop: passo 5, imagem 1 %32
    • Step down from the ladder and play ball.
Conclusão
Now that you've replaced your net, you're ready play some basketball.
3 outras pessoas executaram este guia.
Kevin A Walker
Membro desde: 02/24/15
164 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 23-3, Green Winter 2015 Membro de Cal Poly, Team 23-3, Green Winter 2015
CPSU-GREEN-W15S23G3
Membros da 6
Autoria de 13 guias
3 comentários
Thanks for letting my grandchildren help me from the Basketball Net. Your truly Kelly
akiborja1017 - Responder
i don't have these things were I can like put the net in
leon reichert - Responder
do you mean they dont have the little hooks that the net latches on to onto the hoop?
tayola -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 26
Últimos 7 dias: 192
Últimos 30 dias: 878
Duração total: 111,427
