Introdução
If your Endgame Gear XM1 mouse is intermittently losing connection, or outright does not respond when it is plugged in, the cable may be damaged. With the help of this guide, you can fix your mouse and get it back in working order by replacing the cord.
Unplug the mouse from your computer before beginning this guide.
O que você precisa
Use the plastic spudger to peel off the four rubber feet on the underside of the mouse.
Quase terminado!
Conclusão
