Ir para o conteúdo principal
How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock
O que você precisa
  1. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock, Battery: passo 1, imagem 1 %32 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock, Battery: passo 1, imagem 2 %32 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock, Battery: passo 1, imagem 3 %32
    • Remove the three (3) M3 x 6mm screws that secure the faceplate using a #1 Philips screwdriver.
    • Left side
    • Right side
    • Bottom
  2. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 2, imagem 1 %32 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 2, imagem 2 %32 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 2, imagem 3 %32
    • Remove the faceplate from the lock mechanism by pulling straight out.
  3. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 3, imagem 1 %32 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 3, imagem 2 %32 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 3, imagem 3 %32
    • Remove the battery pack from the lock mechanism by pulling straight up.
  4. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 4, imagem 1 %32 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 4, imagem 2 %32 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 4, imagem 3 %32
    • Remove the batteries from the battery pack.
  5. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 5, imagem 1 %32 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 5, imagem 2 %32 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 5, imagem 3 %32
    • Insert new batteries into the battery pack.
  6. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 6, imagem 1 %32 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 6, imagem 2 %32 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 6, imagem 3 %32
    • Insert the battery pack back into the lock mechanism by pushing straight down.
    • Make sure the label is facing outward.
  7. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 7, imagem 1 %32 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 7, imagem 2 %32 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 7, imagem 3 %32
    • Reattach the faceplate to the lock mechanism by pushing straight in.
  8. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 8, imagem 1 %32 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 8, imagem 2 %32 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 8, imagem 3 %32
    • Reattach the three (3) M3 x 6mm screws that secure the faceplate using a #1 Philips screwdriver.
    • Bottom
    • Right side
    • Left side
Conclusão
That's it! Your Kwikset Home Connect 620 Smart Lock should now be working properly.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 51
Duração total: 294
