Introdução
Use this guide to replace the back cover adhesive by applying it to the frame first.
To determine where you first apply the adhesive, match the contours of the adhesive on the clear side with the back cover and the frame. If your adhesive strip matches the bottom cover, follow this guide instead.
The frame-first adhesive tends to have screw holes in the colored lining.
O que você precisa
If you're re-using your frame, remove the remaining adhesive.
Repeat the same procedure for any remaining adhesive on the back cover.
Before removing any liners, position the adhesive strip with the clear liner facing down over the frame to find the proper orientation.
If the adhesive matches the back cover instead of the frame, follow this cover-first adhesive guide.
Peel the clear liner off of the adhesive strip to expose the adhesive.
Carefully align the sticky side of the adhesive over the edges of the frame.
Press down on the perimeter of the adhesive strip to bond it to the frame.
7 outras pessoas executaram este guia.
