Introdução
Oh no, the arm of your glasses broke!
If you wear standard-hinge eyeglasses (chances are you probably do), this guide can help. Using only a screwdriver and a replacement arm that can be purchased online or in optical stores, you can get back to seeing in no time!
O que você precisa
Remove the screw holding the broken arm by turning it counterclockwise.
