Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
How to Replace a Turntable Cartridge, Stylus, and Headshell
O que você precisa
  1. How to Replace a Turntable Cartridge, Stylus, and Headshell, Cartridge, Stylus, Headshell: passo 1, imagem 1 %32
    • Identify headshell by opening the turntable dustcover.
  2. How to Replace a Turntable Cartridge, Stylus, and Headshell: passo 2, imagem 1 %32
    • Remove stylus from cartridge.
    • Do not pull aggressively as to break the plastic.
  3. How to Replace a Turntable Cartridge, Stylus, and Headshell: passo 3, imagem 1 %32
    • Turn tonearm nut toward you to release headshell from the tonearm.
  4. How to Replace a Turntable Cartridge, Stylus, and Headshell: passo 4, imagem 1 %32
    • Remove screws with phillips screwdriver #0 to release the cartridge.
    • Use standard turntable head screws found at a local audio shop if missing
  5. How to Replace a Turntable Cartridge, Stylus, and Headshell: passo 5, imagem 1 %32
    • Unplug wires from pins.
  6. How to Replace a Turntable Cartridge, Stylus, and Headshell: passo 6, imagem 1 %32
    • Replace with new cartridge
    • Plug pins in reverse from removal
    • Pay attention to matching the colors from wire to pin
    • Screw cartridge in in the same way it was removed.
  7. How to Replace a Turntable Cartridge, Stylus, and Headshell: passo 7, imagem 1 %32
    • Insert new stylus into cartridge before mounting headshell
  8. How to Replace a Turntable Cartridge, Stylus, and Headshell: passo 8, imagem 1 %32
    • Screw assembled headshell onto tonearm.
  9. How to Replace a Turntable Cartridge, Stylus, and Headshell: passo 9, imagem 1 %32
    • Test new needle and allow for a break-in period.
Linha de Chegada
9 outras pessoas executaram este guia.
Javier Torres
Membro desde: 02/24/15
385 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 23-3, Green Winter 2015 Membro de Cal Poly, Team 23-3, Green Winter 2015
CPSU-GREEN-W15S23G3
Membros da 6
Autoria de 13 guias
2 comentários
"on any turntable"? These instructions are only for one specific tonearm and cartridge and apply to a minority of cartridges. This claim is plainly bogus and anyone with a different cartridge is likely to find the instructions useless and potentially hazardous to their equipment.
Howard - Responder
Just commenting to disagree with above. Excellent tutorial and my audio technical cartridge and headshell are similar so it solved my issue. Thanks for the article.
Craig Smith - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 41
Últimos 30 dias: 259
Duração total: 54,191
