Ir para o conteúdo principal
How to Replace a Transition Strip (T Molding)
O que você precisa
  1. How to Replace a Transition Strip (T Molding), Transition Strip (T Molding): passo 1, imagem 1 %32
    • Measure the exact width of the doorway using a tape measure.
  2. How to Replace a Transition Strip (T Molding): passo 2, imagem 1 %32 How to Replace a Transition Strip (T Molding): passo 2, imagem 2 %32 How to Replace a Transition Strip (T Molding): passo 2, imagem 3 %32
    • Mark the T molding based on the doorway measure.
    • Cut the T molding using a sharp saw (table saw).
    • Cutting the T molding can be done for free at the place of purchase.
    • If you don't have access to a sharp saw, cut the T molding using a jigsaw and use sanding paper to soften the end.
  3. How to Replace a Transition Strip (T Molding): passo 3, imagem 1 %32 How to Replace a Transition Strip (T Molding): passo 3, imagem 2 %32 How to Replace a Transition Strip (T Molding): passo 3, imagem 3 %32
    • Remove the old T molding.
    • You can use a pry bar to loosen the T molding.
  4. How to Replace a Transition Strip (T Molding): passo 4, imagem 1 %32 How to Replace a Transition Strip (T Molding): passo 4, imagem 2 %32
    • Use a utility knife to remove all the glue or any material used to keep the old T molding in place.
    • You may use a scraper instead of a utility knife.
    • Clean up the area thoroughly.
  5. How to Replace a Transition Strip (T Molding): passo 5, imagem 1 %32
    • Apply the glue evenly to the gap.
  6. How to Replace a Transition Strip (T Molding): passo 6, imagem 1 %32 How to Replace a Transition Strip (T Molding): passo 6, imagem 2 %32 How to Replace a Transition Strip (T Molding): passo 6, imagem 3 %32
    • Insert the T molding into the gap.
    • Press the T molding firmly onto the ground.
    • No gap should exist between the T molding and the floorings.
  7. How to Replace a Transition Strip (T Molding): passo 7, imagem 1 %32 How to Replace a Transition Strip (T Molding): passo 7, imagem 2 %32
    • Tape the T molding onto the floor.
    • This step ensures the T molding stays in place until the glue dries.
    • Wait 24 hours for the glue to dry.
    • Remove the tapes.
Conclusão
Rojean Noorinayer
Membro desde: 05/12/21
145 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 28
Últimos 30 dias: 159
Duração total: 4,429
