Ir para o conteúdo principal
How to Replace a Three-Prong Plug on a Power Strip
O que você precisa
  1. How to Replace a Three-Prong Plug on a Power Strip, Three-Pole Plug: passo 1, imagem 1 %32
    • Unplug the power strip and place it on a flat, non-metal surface.
  2. How to Replace a Three-Prong Plug on a Power Strip: passo 2, imagem 1 %32 How to Replace a Three-Prong Plug on a Power Strip: passo 2, imagem 2 %32
    • Cut near the base of the original plug, all the way through. Dispose of the old plug.
  3. How to Replace a Three-Prong Plug on a Power Strip: passo 3, imagem 1 %32
    • Before attempting to work with the wires, insert the cord into a piece of heat shrink tubing. This will help to safely seal the wires later.
  4. How to Replace a Three-Prong Plug on a Power Strip: passo 4, imagem 1 %32 How to Replace a Three-Prong Plug on a Power Strip: passo 4, imagem 2 %32
    • Examine the 3 wires inside. You should see green, white, and black. Snip off any stray wires over a trash can.
  5. How to Replace a Three-Prong Plug on a Power Strip: passo 5, imagem 1 %32
    • Strip back about 1/2 inch of the Wire with the wire strippers.
    • Braid the wires by gently twisting each strand so they stay with their same color wires.
  6. How to Replace a Three-Prong Plug on a Power Strip: passo 6, imagem 1 %32
    • Unscrew the hinge on the new plug, set the screw somewhere safe for later.
  7. How to Replace a Three-Prong Plug on a Power Strip: passo 7, imagem 1 %32
    • Make sure you have 3 different colored screws. Gold or dark colored, green and silver or light colored.
  8. How to Replace a Three-Prong Plug on a Power Strip: passo 8, imagem 1 %32 How to Replace a Three-Prong Plug on a Power Strip: passo 8, imagem 2 %32 How to Replace a Three-Prong Plug on a Power Strip: passo 8, imagem 3 %32
    • Pair the black wire to the gold or dark colored screw. Once twisted around the screw clockwise, tighten it.
    • Pair the green wire to the green colored screw. Once twisted around the screw clockwise tighten it.
    • Pair the white wire to the silver or light colored screw. Once twisted around the screw clockwise, tighten it.
  9. How to Replace a Three-Prong Plug on a Power Strip: passo 9, imagem 1 %32 How to Replace a Three-Prong Plug on a Power Strip: passo 9, imagem 2 %32 How to Replace a Three-Prong Plug on a Power Strip: passo 9, imagem 3 %32
    • Close up the new plug and screw it tightly shut.
    • Make sure the plug closes well with the cables and it is not blocking the closing mechanism.
  10. How to Replace a Three-Prong Plug on a Power Strip: passo 10, imagem 1 %32 How to Replace a Three-Prong Plug on a Power Strip: passo 10, imagem 2 %32 How to Replace a Three-Prong Plug on a Power Strip: passo 10, imagem 3 %32
    • Seal the Heat Shrink Tubing by holding the flame of a lighter directly on the tubing, moving it back and forth until the tubing molds itself to the wires.
    • Do not let the flame linger for too long, or you run the risk of ruining the seal.
    • If heat shrink is unavailable, electrical tape works just as well.
  11. How to Replace a Three-Prong Plug on a Power Strip: passo 11, imagem 1 %32 How to Replace a Three-Prong Plug on a Power Strip: passo 11, imagem 2 %32
    • Connect to the wall and enjoy your restored power strip.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 21
Últimos 30 dias: 92
Duração total: 2,828
