Introdução
If your deck is warped, broken, or just need style change, then use this guide to replace your deck.
The deck is the part of the board that you stand on, and with time it is subject to wear and tear. Sometimes, it just snaps in half on you after very heavy and intense use.
Be sure to first obtain the new deck, and purchase grip to go with it. Decks do not come with grip pre-applied, which we will cover how to apply it in this guide.
O que você precisa
Use the 3/8" socket to take off the nut
Remove the nut
Repeat for all four nuts on the truck
Repeat for the second truck
Linha de Chegada
