Ir para o conteúdo principal
How to Replace a Screen Protector on an iPhone 12
O que você precisa
  1. How to Replace a Screen Protector on an iPhone 12, Screen Protector: passo 1, imagem 1 %32 How to Replace a Screen Protector on an iPhone 12, Screen Protector: passo 1, imagem 2 %32 How to Replace a Screen Protector on an iPhone 12, Screen Protector: passo 1, imagem 3 %32
    • If you already have a pre-existing screen protector, you will gently peel of your existing screen protector from the top of you iPhone.
    • If any small pieces of the screen protector are still attached to the phone, genlty peel the pieces off until no more pieces remain.
    • When the screen protector and the pieces are removed, you can dispose of it immediately or set it aside for disposal.
  2. How to Replace a Screen Protector on an iPhone 12: passo 2, imagem 1 %32 How to Replace a Screen Protector on an iPhone 12: passo 2, imagem 2 %32 How to Replace a Screen Protector on an iPhone 12: passo 2, imagem 3 %32
    • Grab the wet cloth from the pack and wipe the screen of the iPhone in order to remove any stain or mark left behind.
  3. How to Replace a Screen Protector on an iPhone 12: passo 3, imagem 1 %32 How to Replace a Screen Protector on an iPhone 12: passo 3, imagem 2 %32
    • With the LCD cloth, wipe and dry the screen of the phone to remove any small debris or dust.
  4. How to Replace a Screen Protector on an iPhone 12: passo 4, imagem 1 %32 How to Replace a Screen Protector on an iPhone 12: passo 4, imagem 2 %32 How to Replace a Screen Protector on an iPhone 12: passo 4, imagem 3 %32
    • Grab the dust sticker and apply it all around on the screen multiple times, until you covered all areas of the iPhone display.
  5. How to Replace a Screen Protector on an iPhone 12: passo 5, imagem 1 %32 How to Replace a Screen Protector on an iPhone 12: passo 5, imagem 2 %32 How to Replace a Screen Protector on an iPhone 12: passo 5, imagem 3 %32
    • Grab the screen protector and remove the plastic that's attached to the sticky part of the screen protector.
    • Align the new screen protector to the iPhone without touching the sticky part.
    • Press down on the screen protector from the top of the iPhone until you reach the bottom.
  6. How to Replace a Screen Protector on an iPhone 12: passo 6, imagem 1 %32 How to Replace a Screen Protector on an iPhone 12: passo 6, imagem 2 %32 How to Replace a Screen Protector on an iPhone 12: passo 6, imagem 3 %32
    • With the new screen protector on the phone, use the anti-bubble card to prevent bubbles from staying in between the iPhone and the screen protector.
    • Push the bubbles towards the edge of the iPhone until you see no more on the screen.
  7. How to Replace a Screen Protector on an iPhone 12: passo 7, imagem 1 %32
    • With the bubbles removed from the screen, the new screen protector for the iPhone 12 is now installed.
    • Dispose of any waste left after the installation.
Conclusão
reveleszacatecas5
Membro desde: 10/24/23
145 Reputação
Autoria de 1 guia
Equipe
CSU Los Angeles, Team 8-3, Ribeiro Fall 2023 Membro de CSU Los Angeles, Team 8-3, Ribeiro Fall 2023
CSULA-RIBEIRO-F23S8G3
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 29
Últimos 30 dias: 198
Duração total: 666
