Ir para o conteúdo principal
How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid
  1. How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid, Receiver Wire: passo 1, imagem 1 %32
    • This is the Widex Evoke 440 Hearing Aid that we will be replacing the receiver wire on. Colors may vary.
  2. How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid: passo 2, imagem 1 %32
    • Look for the exact part number you need, which is on the end of your Receiver.
    • The first letter corresponds to the strength of the receiver. It will be S for small, M for medium, or P for power.
    • The number corresponds to the length of the wire.
    • The next letter corresponds to which side the receiver is for, so it will be either L or R for left or right.
  3. How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid: passo 3, imagem 1 %32 How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid: passo 3, imagem 2 %32
    • Remove the battery from your hearing aid.
  4. How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid: passo 4, imagem 1 %32 How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid: passo 4, imagem 2 %32 How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid: passo 4, imagem 3 %32
    • Put your index finger under the curve in the wire near the base of the receiver.
    • Put your thumb over the receiver wire and grasp it tightly.
    • Pull the wire straight up out of the hearing aid.
  5. How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid: passo 5, imagem 1 %32
    • Your new hearing aid receiver wire will look like this out of the box.
  6. How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid: passo 6, imagem 1 %32 How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid: passo 6, imagem 2 %32
    • Slide the small plug at the end of the receiver into the hearing aid.
    • Push it all the way into the hearing aid by pushing down on the edge of the plug with your fingernail.
  7. How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid: passo 7, imagem 1 %32 How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid: passo 7, imagem 2 %32
    • Put your silicone dome back on the receiver by lining it up with the receiver wire and pressing gently.
  8. How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid: passo 8, imagem 1 %32
    • Put your battery back in.
Linha de Chegada
3 outras pessoas executaram este guia.
Tish Alexander
Membro desde: 09/18/23
238 Reputação
Autoria de 1 guia
2Comentários do guia
Thank you so much for this page. It's the only place on the internet I found that gives the exact instructions for replacing the receiver link. Also the only place that explains exactly what the codes mean that are stamped on the receiver so that I can order the right part!
James McClure - Responder
I'm so glad it was helpful; thank you for letting me know!
Tish Alexander -
Comentar
Visualizações:
Últimas 24 horas: 13
Últimos 7 dias: 62
Últimos 30 dias: 214
Ao todo: 3,449
