Ir para o conteúdo principal
How to Replace a Leaking Set Screw Tub Spout
O que você precisa
  1. How to Replace a Leaking Set Screw Tub Spout, Set Screw Tub Spout: passo 1, imagem 1 %32 How to Replace a Leaking Set Screw Tub Spout, Set Screw Tub Spout: passo 1, imagem 2 %32
    • Cover the shower drain with a plug or a piece of cloth to prevent the screw from falling in.
    • Make sure the water is turned off.
  2. How to Replace a Leaking Set Screw Tub Spout: passo 2, imagem 1 %32 How to Replace a Leaking Set Screw Tub Spout: passo 2, imagem 2 %32 How to Replace a Leaking Set Screw Tub Spout: passo 2, imagem 3 %32
    • Using an 5/32" Allen key, loosen the screw located under the spout.
    • You should not remove the screw. But instead, untighten the screw until it's loose.
  3. How to Replace a Leaking Set Screw Tub Spout: passo 3, imagem 1 %32 How to Replace a Leaking Set Screw Tub Spout: passo 3, imagem 2 %32 How to Replace a Leaking Set Screw Tub Spout: passo 3, imagem 3 %32
    • Gently pull out the spout using your hand and set it aside somewhere.
    • Protip: Wiggle the spout side to side to help pull it out.
  4. How to Replace a Leaking Set Screw Tub Spout: passo 4, imagem 1 %32 How to Replace a Leaking Set Screw Tub Spout: passo 4, imagem 2 %32 How to Replace a Leaking Set Screw Tub Spout: passo 4, imagem 3 %32
    • Using sandpaper or a sponge, gently rub and clean the pipe.
    • This allows for the new set screw tub spout to easily slip on.
    • Once you have finished cleaning the pipe, wipe off the dust with a piece of cloth or paper towel.
  5. How to Replace a Leaking Set Screw Tub Spout: passo 5, imagem 1 %32 How to Replace a Leaking Set Screw Tub Spout: passo 5, imagem 2 %32 How to Replace a Leaking Set Screw Tub Spout: passo 5, imagem 3 %32
    • Take your new set screw tub spout and slide it in gently into the wall.
    • Protip: Wiggle the spout side to side to help push it back in.
  6. How to Replace a Leaking Set Screw Tub Spout: passo 6, imagem 1 %32 How to Replace a Leaking Set Screw Tub Spout: passo 6, imagem 2 %32 How to Replace a Leaking Set Screw Tub Spout: passo 6, imagem 3 %32
    • Retighten the set screw using the 5/32" Allen key.
Conclusão
Turn on the bath water to ensure the set screw tub spout has no leaks and is working as intended.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 15
Últimos 30 dias: 93
Ao todo: 4,513
