Ir para o conteúdo principal
How to Replace a Filter on Whirlpool W10407342B side-by-side refrigerator
O que você precisa
  1. How to Replace a Filter on Whirlpool W10407342B side-by-side refrigerator, Water Filter: passo 1, imagem 1 %32 How to Replace a Filter on Whirlpool W10407342B side-by-side refrigerator, Water Filter: passo 1, imagem 2 %32 How to Replace a Filter on Whirlpool W10407342B side-by-side refrigerator, Water Filter: passo 1, imagem 3 %32
    • Place a towel under the water filter cover door at the base grille.
  2. How to Replace a Filter on Whirlpool W10407342B side-by-side refrigerator: passo 2, imagem 1 %32 How to Replace a Filter on Whirlpool W10407342B side-by-side refrigerator: passo 2, imagem 2 %32 How to Replace a Filter on Whirlpool W10407342B side-by-side refrigerator: passo 2, imagem 3 %32
    • Open the filter cover door.
    • Once the door is open, the filter will eject out.
  3. How to Replace a Filter on Whirlpool W10407342B side-by-side refrigerator: passo 3, imagem 1 %32 How to Replace a Filter on Whirlpool W10407342B side-by-side refrigerator: passo 3, imagem 2 %32
    • Open the door all the way and pull the filter out straight.
    • The filter might be wet so let it drip out on the towel a bit to avoid flinging water across your kitchen floors.
  4. How to Replace a Filter on Whirlpool W10407342B side-by-side refrigerator: passo 4, imagem 1 %32 How to Replace a Filter on Whirlpool W10407342B side-by-side refrigerator: passo 4, imagem 2 %32 How to Replace a Filter on Whirlpool W10407342B side-by-side refrigerator: passo 4, imagem 3 %32
    • Remove the new filter from its packaging and take the coverings off the O-rings.
  5. How to Replace a Filter on Whirlpool W10407342B side-by-side refrigerator: passo 5, imagem 1 %32 How to Replace a Filter on Whirlpool W10407342B side-by-side refrigerator: passo 5, imagem 2 %32 How to Replace a Filter on Whirlpool W10407342B side-by-side refrigerator: passo 5, imagem 3 %32
    • Point the arrow on the filter toward the left and slide it into the filter hole.
    • Doing so will cause the filter cover door to automatically begin closing.
  6. How to Replace a Filter on Whirlpool W10407342B side-by-side refrigerator: passo 6, imagem 1 %32 How to Replace a Filter on Whirlpool W10407342B side-by-side refrigerator: passo 6, imagem 2 %32
    • Close the filter cover door completely.
    • You may need to press hard to snap the filter into the right place.
  7. How to Replace a Filter on Whirlpool W10407342B side-by-side refrigerator: passo 7, imagem 1 %32 How to Replace a Filter on Whirlpool W10407342B side-by-side refrigerator: passo 7, imagem 2 %32 How to Replace a Filter on Whirlpool W10407342B side-by-side refrigerator: passo 7, imagem 3 %32
    • Push the filter indicator switch five times to reset the filter indicator to green.
    • Using a sturdy container to catch the water, depress and hold the water dispenser lever for 5 seconds, then release it for 5 seconds.
    • Repeat until water begins to flow.
    • Once the water begins to flow, continue depressing and releasing the dispenser lever (5 seconds on and 5 seconds off) until a total of 3 gallons had been dispensed.
Conclusão
You have successfully replaced the water filter on your Whirlpool W10407342B side-by-side refrigerator!
Uma outra pessoa concluiu este guia.
Miller Ekas
Membro desde: 09/30/20
145 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 18
Últimos 30 dias: 101
Duração total: 8,258
