Ir para o conteúdo principal
How to Replace a Damaged Gutter Segment
O que você precisa
  1. How to Replace a Damaged Gutter Segment, Eavestrough Gutter Segment: passo 1, imagem 1 %32
    • Identify the section of the gutter system that needs to be replaced, specifically the middle gutter.
  2. How to Replace a Damaged Gutter Segment: passo 2, imagem 1 %32 How to Replace a Damaged Gutter Segment: passo 2, imagem 2 %32
    • Using a screwdriver, remove the screws from the strip that holds the gutter to the wall.
    • Repeat this process for each strip along the length of the gutter.
    • Spread apart the strips to release the gutter.
    • When spreading apart the strips, they may have sharp edges. To ensure your safety, please use caution and wear protective gloves.
  3. How to Replace a Damaged Gutter Segment: passo 3, imagem 1 %32 How to Replace a Damaged Gutter Segment: passo 3, imagem 2 %32 How to Replace a Damaged Gutter Segment: passo 3, imagem 3 %32
    • Locate the connecting points between the bottom gutter and the middle gutter.
    • Using a screwdriver, remove the screws.
    • Separate the bottom gutter from the middle gutter by sliding them apart.
  4. How to Replace a Damaged Gutter Segment: passo 4, imagem 1 %32 How to Replace a Damaged Gutter Segment: passo 4, imagem 2 %32 How to Replace a Damaged Gutter Segment: passo 4, imagem 3 %32
    • Detach the top gutter from the connected fittings.
    • Position yourself securely on a ladder or elevated platform at the appropriate height to access the top gutter.
    • Place the removed top gutter and the middle gutter on the ground.
    • Inspect both the top gutter and the middle gutter for any damage. Assess whether they need to be entirely replaced or if repairs can be made.
    • If the damaged area is serious, you can only replace with a new segment (looking for environmentally friendly materials to protect the earth).
  5. How to Replace a Damaged Gutter Segment: passo 5, imagem 1 %32 How to Replace a Damaged Gutter Segment: passo 5, imagem 2 %32 How to Replace a Damaged Gutter Segment: passo 5, imagem 3 %32
    • Slide the new middle gutter into the top gutter, inserting it gently until they are firmly connected.
    • Double-check that the alignment is correct and there are no gaps between the sections to avoid any drainage.
    • With the middle and top gutters connected, reattach the assembled gutters to the connected fittings.
  6. How to Replace a Damaged Gutter Segment: passo 6, imagem 1 %32 How to Replace a Damaged Gutter Segment: passo 6, imagem 2 %32 How to Replace a Damaged Gutter Segment: passo 6, imagem 3 %32
    • Load a screw into the strip, positioning it so that it can be screwed into the holes of both the strip and the gutter.
    • Fold the strip around the gutter, aligning the holes of the strip with the corresponding holes on the gutter.
    • Screw the screws into the holes of the strip and the gutter, using a screwdriver.
    • Repeat this process for each strip along the length of the new middle gutter.
    • Take care not to overtighten the screw, as it may damage the gutter or strip the threads.
  7. How to Replace a Damaged Gutter Segment: passo 7, imagem 1 %32 How to Replace a Damaged Gutter Segment: passo 7, imagem 2 %32 How to Replace a Damaged Gutter Segment: passo 7, imagem 3 %32
    • Position the bottom gutter in its intended location, ensuring that the holes on both pieces line up properly.
    • Using a screwdriver, tighten the screws to fasten the middle and bottom gutters together.
    • Replacement Complete!
Linha de Chegada
Gavin Luc
Membro desde: 10/19/22
145 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 76
Duração total: 794
