Ir para o conteúdo principal
How to Replace a Croc Ankle Strap Rivet
O que você precisa
  1. How to Replace a Croc Ankle Strap Rivet, Croc Rivet: passo 1, imagem 1 %32 How to Replace a Croc Ankle Strap Rivet, Croc Rivet: passo 1, imagem 2 %32 How to Replace a Croc Ankle Strap Rivet, Croc Rivet: passo 1, imagem 3 %32
    • Use a flathead screwdriver to pry underneath the plastic rivet head.
    • Wiggle the plastic rivet until the head pops off.
  2. How to Replace a Croc Ankle Strap Rivet: passo 2, imagem 1 %32 How to Replace a Croc Ankle Strap Rivet: passo 2, imagem 2 %32 How to Replace a Croc Ankle Strap Rivet: passo 2, imagem 3 %32
    • Use your hands to remove the remaining part of the old rivet from inside the Croc.
  3. How to Replace a Croc Ankle Strap Rivet: passo 3, imagem 1 %32 How to Replace a Croc Ankle Strap Rivet: passo 3, imagem 2 %32 How to Replace a Croc Ankle Strap Rivet: passo 3, imagem 3 %32
    • Flip the Croc strap to the front of the sandal and apply a binder clip to hold the strap in place.
  4. How to Replace a Croc Ankle Strap Rivet: passo 4, imagem 1 %32 How to Replace a Croc Ankle Strap Rivet: passo 4, imagem 2 %32 How to Replace a Croc Ankle Strap Rivet: passo 4, imagem 3 %32
    • Insert the end of the new rivet through the hole from the inside of the Croc.
  5. How to Replace a Croc Ankle Strap Rivet: passo 5, imagem 1 %32 How to Replace a Croc Ankle Strap Rivet: passo 5, imagem 2 %32 How to Replace a Croc Ankle Strap Rivet: passo 5, imagem 3 %32
    • Place the head of the new rivet through the hole of the Croc strap.
    • Move the Croc strap so that the rivet head aligns with the opening of the rivet tail.
  6. How to Replace a Croc Ankle Strap Rivet: passo 6, imagem 1 %32 How to Replace a Croc Ankle Strap Rivet: passo 6, imagem 2 %32
    • Use a flathead screwdriver to turn the rivet head clockwise to tighten it.
  7. How to Replace a Croc Ankle Strap Rivet: passo 7, imagem 1 %32 How to Replace a Croc Ankle Strap Rivet: passo 7, imagem 2 %32 How to Replace a Croc Ankle Strap Rivet: passo 7, imagem 3 %32
    • Remove the binder clip.
  8. How to Replace a Croc Ankle Strap Rivet: passo 8, imagem 1 %32 How to Replace a Croc Ankle Strap Rivet: passo 8, imagem 2 %32 How to Replace a Croc Ankle Strap Rivet: passo 8, imagem 3 %32
    • To test for tightness, move the strap towards the back of the sandal.
    • If the strap bends instead of rotating freely, the screw is on too tight.
    • If necessary, to loosen the Croc strap, rotate the rivet head counterclockwise using a flathead screwdriver.
  9. How to Replace a Croc Ankle Strap Rivet: passo 9, imagem 1 %32 How to Replace a Croc Ankle Strap Rivet: passo 9, imagem 2 %32 How to Replace a Croc Ankle Strap Rivet: passo 9, imagem 3 %32
    • Check that the Croc strap can rotate freely.
Conclusão
Uma outra pessoa concluiu este guia.
Andy
Membro desde: 04/19/23
178 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 2-1, Morris Spring 2023 Membro de UC Davis, Team 2-1, Morris Spring 2023
UCD-MORRIS-S23S2G1
3 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 16
Últimos 7 dias: 105
Últimos 30 dias: 506
Ao todo: 25,136
