Ir para o conteúdo principal
How to Replace a Corroded Car Battery Terminal
O que você precisa
  1. How to Replace a Corroded Car Battery Terminal, Car Battery Terminal: passo 1, imagem 1 %32 How to Replace a Corroded Car Battery Terminal, Car Battery Terminal: passo 1, imagem 2 %32
    • Remember to remove your car key from the ignition and shut off the car before performing this guide.
    • Locate the terminals on the top of the car battery. Next to each terminal is a positive(+) or negative(-) sign, indicating the charge.
    • The positive terminal looks to be in working order, but the negative end has a lot of corrosion buildup. This terminal needs to be replaced.
  2. How to Replace a Corroded Car Battery Terminal: passo 2, imagem 1 %32 How to Replace a Corroded Car Battery Terminal: passo 2, imagem 2 %32
    • Find the nut located on the side of the terminal.
    • Using an adjustable wrench, rotate the nut counterclockwise to loosen it.
    • Use an appropriately-sized wrench or socket, not channel locks as shown in the photo.
    • You do not need to loosen the nut all the way off the bolt, but just enough to loosen the terminal's grip on the node.
  3. How to Replace a Corroded Car Battery Terminal: passo 3, imagem 1 %32 How to Replace a Corroded Car Battery Terminal: passo 3, imagem 2 %32
    • Always remember to remove the negative terminal first before the positive terminal. This will prevent shorting to the ground and possibly causing shock or a fire.
    • Carefully use a rag to lift up the terminal off of the battery node.
    • Be cautious when handling battery corrosion, as it can irritate the skin and is harmful if it comes in contact with your eyes.
    • Place the terminal on a rag or towel and make sure it doesn't come in contact with the battery node.
  4. How to Replace a Corroded Car Battery Terminal: passo 4, imagem 1 %32 How to Replace a Corroded Car Battery Terminal: passo 4, imagem 2 %32
    • On the positive terminal, locate the nut along the side.
    • Using the wrench, rotate the nut counterclockwise.
    • You do not need to fully loosen the nut off the bolt, but just enough for the terminal to be easily removed from the node.
  5. How to Replace a Corroded Car Battery Terminal: passo 5, imagem 1 %32 How to Replace a Corroded Car Battery Terminal: passo 5, imagem 2 %32
    • Using a rag, carefully remove the positive terminal from the battery node.
    • Place the terminal on a rag or towel, and make sure it does not come into contact with the battery node.
  6. How to Replace a Corroded Car Battery Terminal: passo 6, imagem 1 %32 How to Replace a Corroded Car Battery Terminal: passo 6, imagem 2 %32 How to Replace a Corroded Car Battery Terminal: passo 6, imagem 3 %32
    • On the negative terminal, locate the nut on the side facing upwards.
    • Using the wrench, rotate the nut counterclockwise and remove it from the bolt.
  7. How to Replace a Corroded Car Battery Terminal: passo 7, imagem 1 %32 How to Replace a Corroded Car Battery Terminal: passo 7, imagem 2 %32 How to Replace a Corroded Car Battery Terminal: passo 7, imagem 3 %32
    • Take the wire plate on top and remove it carefully from the bolt.
    • At this point, it is fine to handle the metal plate with your hands since the terminals are disconnected from the battery and there is nothing completing the circuit.
    • Remove the bottom wire plate from the bolt, placing it carefully to the side.
  8. How to Replace a Corroded Car Battery Terminal: passo 8, imagem 1 %32 How to Replace a Corroded Car Battery Terminal: passo 8, imagem 2 %32
    • Set aside the old battery terminal, and replace it with the new one.
    • Replace the wire plates in the order they were taken off.
    • Although it is not necessary that the plates be placed in the same order again, it is generally a good idea to go with the order that it came in.
  9. How to Replace a Corroded Car Battery Terminal: passo 9, imagem 1 %32 How to Replace a Corroded Car Battery Terminal: passo 9, imagem 2 %32
    • Place the flat washer and the screw-on head that came with the battery terminal onto the vertical bolt.
    • Tighten the head clockwise and make sure the wire plates are secured.
    • Not all battery terminal packs come with a washer and screw-on head. If your pack comes with a nut, use the wrench and tighten the bolt clockwise.
  10. How to Replace a Corroded Car Battery Terminal: passo 10, imagem 1 %32
    • Using a rag, place the positive terminal back onto the positive node.
  11. How to Replace a Corroded Car Battery Terminal: passo 11, imagem 1 %32
    • Place the negative terminal back onto the negative node.
  12. How to Replace a Corroded Car Battery Terminal: passo 12, imagem 1 %32 How to Replace a Corroded Car Battery Terminal: passo 12, imagem 2 %32 How to Replace a Corroded Car Battery Terminal: passo 12, imagem 3 %32
    • On the negative terminal, use the wrench to rotate the side nut clockwise to tighten it.
    • Next, perform the same action on the side nut of the positive terminal.
    • To ensure a secure connection, be sure the nut is snug and that the terminal can't come off easily.
Linha de Chegada
17 outras pessoas executaram este guia.
David Wright
Membro desde: 02/23/15
655 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 12-4, Green Winter 2015 Membro de Cal Poly, Team 12-4, Green Winter 2015
CPSU-GREEN-W15S12G4
Membros da 5
Autoria de 9 guias
8 comentários
Nice post. Shop car battery at batterybhai and their expert technical team come to install the battery with all battery replacement tools kit.
mayank tanwar - Responder
very interesting post. Thanks for sharing it.
https://www.sarexports.com/product-categ...
Raman Malik - Responder
I change negative terminal to new one still have corrosion why?
אנדריי מזילו - Responder
They are corrotion after doinging this within a4 to 5 month time the red cable is worst
Carol - Responder
Use Petroleum-Jelly (preferably) OR if not there then
use Vaseline onto both the Terminals( +, -ive) to prevent rusting of your both terminals of Battery PLEASE .
SANJAY KHANDELWAL -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 30
Últimos 7 dias: 163
Últimos 30 dias: 845
Duração total: 131,031
