Ir para o conteúdo principal
How to Replace a Coffee Tabletop Glass
O que você precisa
  1. How to Replace a Coffee Tabletop Glass, Coffee Table Glass: passo 1, imagem 1 %32 How to Replace a Coffee Tabletop Glass, Coffee Table Glass: passo 1, imagem 2 %32
    • Flip the coffee table base upside down on an empty area.
  2. How to Replace a Coffee Tabletop Glass: passo 2, imagem 1 %32
    • Use a cleaning spray to clean the surface of the glass table.
    • Use gloves while cleaning the table. The glass cleaner spray may contain toxic chemicals.
  3. How to Replace a Coffee Tabletop Glass: passo 3, imagem 1 %32 How to Replace a Coffee Tabletop Glass: passo 3, imagem 2 %32
    • Use a Phillips #2 screwdriver to remove one 1/4 in.-20 x 1-1/2 in. socket cap screw from the side of the glass.
    • Repeat the process for the other 1/4 in.-20 x 1-1/2 in. socket cap screw.
    • The appearance of this screw may differ from table to table, but the procedure remains the same. Use the appropriate screwdriver to open the screws.
  4. How to Replace a Coffee Tabletop Glass: passo 4, imagem 1 %32 How to Replace a Coffee Tabletop Glass: passo 4, imagem 2 %32
    • Remove the coffee table legs piece by piece.
  5. How to Replace a Coffee Tabletop Glass: passo 5, imagem 1 %32
    • Remove the glass.
    • Remember that glass can be shattered or partially damaged. Use gloves to avoid possible cuts.
  6. How to Replace a Coffee Tabletop Glass: passo 6, imagem 1 %32
    • Replace the broken/ damaged glass with the new one.
Conclusão
Jasrin Kaur
Membro desde: 05/10/21
133 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 46
Ao todo: 3,003
