Ir para o conteúdo principal
How to Replace a Button with a Sewing Machine
O que você precisa
  1. How to Replace a Button with a Sewing Machine, Clothing Button: passo 1, imagem 1 %32
    • Attach an open toed presser foot to your machine.
  2. How to Replace a Button with a Sewing Machine: passo 2, imagem 1 %32
    • Thread your sewing machine with the proper colored thread.
  3. How to Replace a Button with a Sewing Machine: passo 3, imagem 1 %32
    • Set your machine to a zig-zag stitch setting.
    • Adjust the stitch length to zero.
  4. How to Replace a Button with a Sewing Machine: passo 4, imagem 1 %32 How to Replace a Button with a Sewing Machine: passo 4, imagem 2 %32
    • Place the button under the presser foot and manually lower the needle to make sure that it is lined up with the first hole on the right.
    • Continue manually turning the needle to make sure that it clears the second hole on the left.
    • If the second hole is not lined up, adjust the stitch width accordingly.
  5. How to Replace a Button with a Sewing Machine: passo 5, imagem 1 %32
    • Begin pushing on the foot pedal.
    • If the button has two holes, make about 10 stitches, or until the button is securely fastened.
    • If the button has four holes, sew diagonally about 5 stitches, pivot, and repeat on the opposite diagonal, forming an X.
  6. How to Replace a Button with a Sewing Machine: passo 6, imagem 1 %32
    • Remove the finished garment from under the presser foot by clipping and leaving about 4 inches of excess thread.
  7. How to Replace a Button with a Sewing Machine: passo 7, imagem 1 %32
    • Pull the top threads to the back of the garment.
    • Accomplish this by tugging on the bottom of the bobbin thread, forming a loop.
    • Using either your seam ripper or scissors, place the tip in the middle of the loop and pull it through. All four threads should be on the back of the garment.
  8. How to Replace a Button with a Sewing Machine: passo 8, imagem 1 %32
    • Secure the button by tying the four threads together with a knot.
    • Clip the threads close to the knot.
  9. How to Replace a Button with a Sewing Machine: passo 9, imagem 1 %32
    • The button is now finished and ready to be used.
Conclusão
After following these steps, your garment will now be fixed.
Jackson Williams
Membro desde: 09/19/22
169 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 79
Ao todo: 1,579
