Ir para o conteúdo principal
How to Replace a Broken Window Wand Tilt Mechanism
  1. How to Replace a Broken Window Wand Tilt Mechanism, Wand Tilt Mechanism: passo 1, imagem 1 %32 How to Replace a Broken Window Wand Tilt Mechanism, Wand Tilt Mechanism: passo 1, imagem 2 %32 How to Replace a Broken Window Wand Tilt Mechanism, Wand Tilt Mechanism: passo 1, imagem 3 %32
    • Lift up the wand sleeve with your fingers to clear access for the wand to slide out.
    • Once the sleeve is pushed up, rotate the wand horizontally to unhook it from the tilt mechanism.
  2. How to Replace a Broken Window Wand Tilt Mechanism: passo 2, imagem 1 %32 How to Replace a Broken Window Wand Tilt Mechanism: passo 2, imagem 2 %32
    • Lift the header board off the window shade by gently prying up and away from the window blind.
  3. How to Replace a Broken Window Wand Tilt Mechanism: passo 3, imagem 1 %32 How to Replace a Broken Window Wand Tilt Mechanism: passo 3, imagem 2 %32 How to Replace a Broken Window Wand Tilt Mechanism: passo 3, imagem 3 %32
    • Unhook the end clips on the window blind by pulling with your fingers toward yourself in an upward motion.
  4. How to Replace a Broken Window Wand Tilt Mechanism: passo 4, imagem 1 %32 How to Replace a Broken Window Wand Tilt Mechanism: passo 4, imagem 2 %32
    • Remove the window blind by pulling it away from the brackets.
  5. How to Replace a Broken Window Wand Tilt Mechanism: passo 5, imagem 1 %32 How to Replace a Broken Window Wand Tilt Mechanism: passo 5, imagem 2 %32 How to Replace a Broken Window Wand Tilt Mechanism: passo 5, imagem 3 %32
    • Slide the end cap off the header to allow for more access.
    • Lift the center rod in an upward motion to unlock it from the header.
  6. How to Replace a Broken Window Wand Tilt Mechanism: passo 6, imagem 1 %32 How to Replace a Broken Window Wand Tilt Mechanism: passo 6, imagem 2 %32 How to Replace a Broken Window Wand Tilt Mechanism: passo 6, imagem 3 %32
    • Remove the tilt wand mechanism by sliding it off the center rod.
  7. How to Replace a Broken Window Wand Tilt Mechanism: passo 7, imagem 1 %32 How to Replace a Broken Window Wand Tilt Mechanism: passo 7, imagem 2 %32 How to Replace a Broken Window Wand Tilt Mechanism: passo 7, imagem 3 %32
    • Install the new tilt wand mechanism by sliding it on the center rod.
    • Once slid into position, reinsert the center rod by pushing down on the assembly.
  8. How to Replace a Broken Window Wand Tilt Mechanism: passo 8, imagem 1 %32
    • Visually inspect alignment, fitment, and proper function of the newly installed tilt wand mechanism.
    • Insure the clip is securely held in place.
Conclusão
1Comentário do guia
Thank you, my new apartment has a broken wind tilter mechanism. The plastic piece that hooks into the wand broke off the blind tilter. I have no idea what brand these vinyl two inch binds are. Can I glue the plastic piece back
Peggy G. Blass - Responder
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 40
Últimos 30 dias: 206
Ao todo: 23,198
