Ir para o conteúdo principal
How to Replace a Bicycle Bell Disc
O que você precisa
  1. How to Replace a Bicycle Bell Disc, Disc Bell: passo 1, imagem 1 %32 How to Replace a Bicycle Bell Disc, Disc Bell: passo 1, imagem 2 %32
    • Unscrew the exterior bell housing by rotating clockwise, then remove the housing.
  2. How to Replace a Bicycle Bell Disc: passo 2, imagem 1 %32 How to Replace a Bicycle Bell Disc: passo 2, imagem 2 %32
    • Rotate the parallel bars clockwise until they separate from the rod they're mounted on.
  3. How to Replace a Bicycle Bell Disc: passo 3, imagem 1 %32 How to Replace a Bicycle Bell Disc: passo 3, imagem 2 %32
    • Remove the rubber discs.
    • Grab your new rubber discs and insert one at each end of the parallel bars.
    • Make sure center of the rubber discs are held in place by the pins.
  4. How to Replace a Bicycle Bell Disc: passo 4, imagem 1 %32
    • Test and rotate the discs with your finger to see if it is the appropriate size.
    • If the disc does not rotate easily, change the size of your metal disc to a narrower one.
  5. How to Replace a Bicycle Bell Disc: passo 5, imagem 1 %32 How to Replace a Bicycle Bell Disc: passo 5, imagem 2 %32
    • Rotate the parallel bars counterclockwise, into their original position.
  6. How to Replace a Bicycle Bell Disc: passo 6, imagem 1 %32 How to Replace a Bicycle Bell Disc: passo 6, imagem 2 %32
    • Replace the exterior housing and rotate it counterclockwise until it's fully secure.
Conclusão
Your bell should now be ringing like new!
Susan
Membro desde: 01/19/22
133 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 19
Últimos 30 dias: 84
Duração total: 600
