Ir para o conteúdo principal
How to Replace a Beaded Bracelet String
O que você precisa
  1. How to Replace a Beaded Bracelet String, String: passo 1, imagem 1 %32 How to Replace a Beaded Bracelet String, String: passo 1, imagem 2 %32
    • Test your bracelet by wearing it on your wrist.
    • If it is loose, sagging (as pictured), or fully snapped, this is a sign that you may need to replace the string.
  2. How to Replace a Beaded Bracelet String: passo 2, imagem 1 %32
    • Cut the old string using scissors.
  3. How to Replace a Beaded Bracelet String: passo 3, imagem 1 %32
    • Separate the beads from the old string.
  4. How to Replace a Beaded Bracelet String: passo 4, imagem 1 %32
    • Measure the new string by wrapping it 1.5 times around your wrist.
    • If you want a loose fit, add extra slack, otherwise pull it flush against skin.
    • Make sure to leave at least 2 in (5.1cm) of excess string for the knot.
  5. How to Replace a Beaded Bracelet String: passo 5, imagem 1 %32
    • Cut the new string at the desired length using scissors.
  6. How to Replace a Beaded Bracelet String: passo 6, imagem 1 %32
    • Thread the beads onto the new string one at a time.
    • You can use tweezers to hold the beads as you thread.
  7. How to Replace a Beaded Bracelet String: passo 7, imagem 1 %32 How to Replace a Beaded Bracelet String: passo 7, imagem 2 %32
    • Tie a square knot to secure the bracelet.
    • Cross both ends to form an "X" shape.
    • Loop one end of the string over the other to form a simple knot.
    • Tie another simple knot, but this time, loop in the opposite direction. If you initially looped the right side over the left, loop the left side over the right, and vice versa.
    • Pull tight to form a square knot.
  8. How to Replace a Beaded Bracelet String: passo 8, imagem 1 %32
    • As an optional step, apply a dot of super glue to the knot.
    • Wait until the super glue fully dries before moving on, otherwise the knot may come undone.
  9. How to Replace a Beaded Bracelet String: passo 9, imagem 1 %32
    • Trim the excess string.
    • Make sure to leave at least 1/2 in (1.3cm) of excess string for the knot.
  10. How to Replace a Beaded Bracelet String: passo 10, imagem 1 %32 How to Replace a Beaded Bracelet String: passo 10, imagem 2 %32
    • Test your bracelet by wearing it again. It should have a tighter fit.
Conclusão
Lucas Wang
Membro desde: 01/30/24
181 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 2-5, Andersen Winter 2024 Membro de UC Davis, Team 2-5, Andersen Winter 2024
UCD-ANDERSEN-W24S2G5
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 31
Duração total: 187
