Introdução
Replacing broken buckles is one of the most common backpack repairs. On this guide we will teach you a quick solution on how to solve this problem.
This guide provides a solution that requires stitching. If you need a simplified version, check out this guide.
O que você precisa
Identify where the broken buckle is and prepare the tools needed for the repair.
Use a seam ripper to unstitch the strap.
Remove the broken buckle and check that it is compatible with the replacement part.
Tip: The new buckle size must match the strap width.
Set the top part of the buckle aside (green circle).
Take the bottom part of the buckle (blue circle) and put it into the strap.
Hold it together with both hands and then insert it into the seam of the backpack.
Following the last step, keep holding together the strap with the bottom buckle with both hands and gently place it on the sewing machine.
Once the strap is set in place, start stitching the area.
Use a pair of scissors to cut any loose threads.
Repeat the previous steps to stitch the top buckle piece.
🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
