Ir para o conteúdo principal
How to Replace a 2009-2015 Toyota Venza Brake Light
O que você precisa
  1. How to Replace a 2009-2015 Toyota Venza Brake Light, Incandescent Brake Light: passo 1, imagem 1 %32
    • Turn the car completely off and wait 30 minutes to ensure that the bulb is not hot.
    • If the car has not been on recently, then skip this step.
  2. How to Replace a 2009-2015 Toyota Venza Brake Light: passo 2, imagem 1 %32 How to Replace a 2009-2015 Toyota Venza Brake Light: passo 2, imagem 2 %32
    • Open the back trunk.
  3. How to Replace a 2009-2015 Toyota Venza Brake Light: passo 3, imagem 1 %32 How to Replace a 2009-2015 Toyota Venza Brake Light: passo 3, imagem 2 %32 How to Replace a 2009-2015 Toyota Venza Brake Light: passo 3, imagem 3 %32
    • Use a flathead screwdriver to remove the vent located on the inside wall of the trunk.
  4. How to Replace a 2009-2015 Toyota Venza Brake Light: passo 4, imagem 1 %32 How to Replace a 2009-2015 Toyota Venza Brake Light: passo 4, imagem 2 %32
    • Carefully reach your arm into the vent and locate the back of the socket.
    • Turn the socket counterclockwise to loosen it.
    • When loose, pull it out into view.
    • The brake bulb socket will be towards the top of the vent.
    • Ensure that bulb has had at least 30 minutes to cool. Touching the bulb while it is hot could result in burns.
  5. How to Replace a 2009-2015 Toyota Venza Brake Light: passo 5, imagem 1 %32 How to Replace a 2009-2015 Toyota Venza Brake Light: passo 5, imagem 2 %32
    • Gently pull on the base of the bulb to loosen it from the socket.
    • When loose, remove the bulb from the socket.
  6. How to Replace a 2009-2015 Toyota Venza Brake Light: passo 6, imagem 1 %32
    • Carefully discard of the old bulb, and acquire the new bulb.
    • Wearing latex gloves when handling the new bulb(s) is highly recommended.
  7. How to Replace a 2009-2015 Toyota Venza Brake Light: passo 7, imagem 1 %32
    • Add bulb grease to the base of the new bulb.
  8. How to Replace a 2009-2015 Toyota Venza Brake Light: passo 8, imagem 1 %32
    • Return bulb to the socket by gently pushing the base of bulb into the empty socket until it clicks in.
  9. How to Replace a 2009-2015 Toyota Venza Brake Light: passo 9, imagem 1 %32
    • Reach your arm into the vent and locate the socket’s hole.
    • Replace the bulb and socket by screwing clockwise to tighten it.
  10. How to Replace a 2009-2015 Toyota Venza Brake Light: passo 10, imagem 1 %32 How to Replace a 2009-2015 Toyota Venza Brake Light: passo 10, imagem 2 %32
    • Replace the vent into the wall of the trunk.
    • You will know that the vent is properly closed when it “pops” into place.
  11. How to Replace a 2009-2015 Toyota Venza Brake Light: passo 11, imagem 1 %32
    • To test your new brake light, have an individual stand behind your car while you press on the brake. The light should come on when the brake is pressed.
    • Enjoy the new lights!
Conclusão
To replace your brake light on the other side, follow these same instructions. Otherwise, safe travels!
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 27
Últimos 30 dias: 89
Duração total: 1,343
