Ir para o conteúdo principal
How to Replace Your Cabin Filter
    1. How to Replace Your Cabin Filter, How to Replace Your Cabin Filter: passo 1, imagem 1 %32 How to Replace Your Cabin Filter, How to Replace Your Cabin Filter: passo 1, imagem 2 %32
      • Open your glovebox, and look for the tamper. Put a little outward pressure on it; it should just pop off.
      Pergunte ao FixBot
      Comentar
    2. How to Replace Your Cabin Filter: passo 2, imagem 1 %32 How to Replace Your Cabin Filter: passo 2, imagem 2 %32
      • Squeeze the sides of the glove box and lower.
      Pergunte ao FixBot
      Comentar
    3. How to Replace Your Cabin Filter: passo 3, imagem 1 %32
      • Remove the glove box from its hinges and set aside.
      Pergunte ao FixBot
      Comentar
    4. How to Replace Your Cabin Filter: passo 4, imagem 1 %32 How to Replace Your Cabin Filter: passo 4, imagem 2 %32
      • Pull gently to remove the cabin filter. Some cars may have a cover that must be removed before the cabin filter can be accessed. Be sure to note how the cabin filter was installed so you can install the new one in the same manner.
      Pergunte ao FixBot
      Comentar
      • Install your new cabin filter.
      Pergunte ao FixBot
      Comentar
Conclusão
To reassemble, carefully place the glove box back on its hinges, squeeze the sides, and reattach the damper. That's it. You've changed your cabin filter.
7 outras pessoas executaram este guia.
Chaya Milchtein
Membro desde: 07/06/23
1.267 Reputação
Autoria de 5 guias
3Comentários do guia
My non factory air filter makes a constant whistling sound when installed and the heater on. Toyota decided to “fix” it by just removing it. No more whistling but no more filter either. They said I could buy a new factory filter and they would install it but I don't have the $80 it costs. Any thoughts or suggestions? Also does your book have pics? I really liked the pics above for the air filter replacement info. Thanks.
meanqueen80 - Responder Compartilhar
我的车是尼桑祺达,我已经更换了车内空调滤网,但是我感觉总是有灰尘以出风口飞出,为什么❓
Kevin - Responder Compartilhar
How on a chevy 2013 silverado
Torres - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 39
Últimos 7 dias: 202
Últimos 30 dias: 680
Ao todo: 3,232
