Introdução
Dresser slides often break, making the slides difficult to use. Buying new furniture can be expensive, and the low-quality production of fast furniture leads to continuous waste of natural resources. To save money and reduce environmental impact, this guide focuses on using recycled wood to repair dresser slides, maintaining the quality of your furniture. A few steps require power tools, so be sure to use them cautiously to avoid harm.
O que você precisa
Place the dresser drawer on a flat surface.
Measure the amount of wood needed to replace the bottom of the dresser by placing the measuring tape side to side.
Two corner braces will be placed on the corners where the glue was placed to further keep it in place. Beginning on the right side of the dresser (optional where you start).
Using your hands measure and steady the corner brace placement to place it on the upper corner of the side.
Use your power drill to screw in holes where you measured the corner brace using 1 inch drywall screws.
