Ir para o conteúdo principal
How to Replace Underside Fabric of a Chair
O que você precisa
  1. How to Replace Underside Fabric of a Chair, Underside Fabric: passo 1, imagem 1 %32
    • Turn the armchair on its back.
  2. How to Replace Underside Fabric of a Chair: passo 2, imagem 1 %32
    • Use pliers to remove the staples from the chair frame.
    • If the staples are too difficult to remove, cut away the fabric with scissors.
  3. How to Replace Underside Fabric of a Chair: passo 3, imagem 1 %32
    • Measure out the dimensions of the perimeter of the chair frame.
    • Add an extra inch to each side to allow for error.
  4. How to Replace Underside Fabric of a Chair: passo 4, imagem 1 %32 How to Replace Underside Fabric of a Chair: passo 4, imagem 2 %32
    • Trace the dimensions onto the new fabric.
    • Cut along the traced lines.
  5. How to Replace Underside Fabric of a Chair: passo 5, imagem 1 %32
    • Fold under approximately a 1-inch allowance from the fabric’s edges.
    • Adjust the folded edges as needed to the correct size.
  6. How to Replace Underside Fabric of a Chair: passo 6, imagem 1 %32 How to Replace Underside Fabric of a Chair: passo 6, imagem 2 %32
    • Use a staple gun to staple the fabric to the chair frame starting at one corner.
    • If the staples do not go all the way into the chair frame, tap lightly with a hammer.
  7. How to Replace Underside Fabric of a Chair: passo 7, imagem 1 %32
    • Sit the chair upright and make sure the fabric is not visible or sagging.
    • If the fabric is visible, remove the staples from the closest corner and pull taut.
Linha de Chegada
3 outras pessoas executaram este guia.
Nicole Keller
Membro desde: 06/09/16
300 Reputação
Autoria de 1 guia
Equipe
Texas Tech, Team 3-3, Rauch SU 2016 Membro de Texas Tech, Team 3-3, Rauch SU 2016
TTU-RAUCH-SU16S3G3
2 Membros
1 Guia de autoria
2Comentários do guia
excellent ways to repair the home furniture. thanks for your ways of writing such a good article about furniture.
Nice post written by Nicole Keller.
http://www.birchi.in/kids-and-baby/kids-...
Birchi In - Responder
Thanks a lot! Wish I knew this a couple of weeks ago. Instead, I went and bought two all new 1 seater sofas in Sydney,
Lucas Bergman - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 18
Últimos 30 dias: 81
Ao todo: 25,035
