Ir para o conteúdo principal
How to Replace The Bulb In A Spice Lab Himalayan Crystal Salt Lamp
  1. How to Replace The Bulb In A Spice Lab Himalayan Crystal Salt Lamp, Spice Lab Himalayan Crystal Salt Lamp Bulb Replacement: passo 1, imagem 1 %32
    • Rotate the power switch in the counterclockwise direction to halt electricity flow to the lamp.
    • Be sure to unplug the lamp to mitigate risk.
    • Wait 5-10 minutes to allow the bulb to cool before continuing.
    • Salt lamps, especially this model, are very dense and capable of causing damage to you or your environment if dropped.
    • Be sure to perform this fix on a sturdy and level surface.
  2. How to Replace The Bulb In A Spice Lab Himalayan Crystal Salt Lamp: passo 2, imagem 1 %32
    • Flip the lamp so that the base is accessible.
  3. How to Replace The Bulb In A Spice Lab Himalayan Crystal Salt Lamp: passo 3, imagem 1 %32
    • Using your hands, pull the black circular light fixture out of the salt lamp.
  4. How to Replace The Bulb In A Spice Lab Himalayan Crystal Salt Lamp: passo 4, imagem 1 %32
    • Using your fingers, twist the light bulb in the counterclockwise direction to remove the bulb.
  5. How to Replace The Bulb In A Spice Lab Himalayan Crystal Salt Lamp: passo 5, imagem 1 %32
    • Screw an E12 light bulb into the empty socket.
    • E12 light bulbs are 12 millimeters in diameter.
Conclusão
Hopefully this fix has reinvigorated your salt lamp. Thank you for using our guide
Uma outra pessoa concluiu este guia.
Matthew Atwill
Membro desde: 02/20/19
145 Reputação
Autoria de 1 guia
Um comentário
replacing salt lamp bulb is not a big deal , but finding a good salt lamp bulb which lasts long is hard
Jackie Sullivan - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 17
Duração total: 5,569
