Ir para o conteúdo principal
How to Replace T-fal Avante T24-B Toaster Lever
O que você precisa
  1. How to Replace T-fal Avante T24-B Toaster Lever, T-fal Avante T24-B Toaster Lever: passo 1, imagem 1 %32
    • Make sure the toaster is unplugged before beginning.
  2. How to Replace T-fal Avante T24-B Toaster Lever: passo 2, imagem 1 %32 How to Replace T-fal Avante T24-B Toaster Lever: passo 2, imagem 2 %32 How to Replace T-fal Avante T24-B Toaster Lever: passo 2, imagem 3 %32
    • Remove the snap-on buttons from the front of the toaster.
    • They can be removed by pulling with your hands or gently prying with a flat tool.
  3. How to Replace T-fal Avante T24-B Toaster Lever: passo 3, imagem 1 %32 How to Replace T-fal Avante T24-B Toaster Lever: passo 3, imagem 2 %32 How to Replace T-fal Avante T24-B Toaster Lever: passo 3, imagem 3 %32
    • Flip the toaster so that you can see its underside.
    • Remove the seven 20 mm Torx T3 screws from the bottom of the toaster.
  4. How to Replace T-fal Avante T24-B Toaster Lever: passo 4, imagem 1 %32 How to Replace T-fal Avante T24-B Toaster Lever: passo 4, imagem 2 %32
    • Turn the toaster so that you can access the back of the toaster
    • Remove the 3 15 mm Torx T3 screws from the back of the toaster.
  5. How to Replace T-fal Avante T24-B Toaster Lever: passo 5, imagem 1 %32 How to Replace T-fal Avante T24-B Toaster Lever: passo 5, imagem 2 %32
    • Pull off the toaster casing.
  6. How to Replace T-fal Avante T24-B Toaster Lever: passo 6, imagem 1 %32 How to Replace T-fal Avante T24-B Toaster Lever: passo 6, imagem 2 %32
    • Unplug the casing so that it does not get in your way.
    • Unplug both wires connecting the casing to the internals of the toaster.
  7. How to Replace T-fal Avante T24-B Toaster Lever: passo 7, imagem 1 %32 How to Replace T-fal Avante T24-B Toaster Lever: passo 7, imagem 2 %32 How to Replace T-fal Avante T24-B Toaster Lever: passo 7, imagem 3 %32
    • Pry both sides of the broken lever at the front of the toaster away and remove it.
  8. How to Replace T-fal Avante T24-B Toaster Lever: passo 8, imagem 1 %32 How to Replace T-fal Avante T24-B Toaster Lever: passo 8, imagem 2 %32 How to Replace T-fal Avante T24-B Toaster Lever: passo 8, imagem 3 %32
    • Snap the replacement lever into place.
    • Attach one side first, then snap the other side on to fully attach the lever.
Conclusão
Cameron Johnson
Membro desde: 01/16/23
157 Reputação
Autoria de 1 guia
Equipe
2 comentários
Thank you so much!
S J - Responder
where do you get the replacement lever ?
Francois Rehel - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 29
Duração total: 547
