Ir para o conteúdo principal
How to Replace Sequins or Beads
O que você precisa
  1. How to Replace Sequins or Beads, How to Replace Sequins or Beads: passo 1, imagem 1 %32
    • Gather the missing sequin, a needle, and thread. Put the thread through the needle.
  2. How to Replace Sequins or Beads: passo 2, imagem 1 %32
    • Double knot both ends of the thread.
  3. How to Replace Sequins or Beads: passo 3, imagem 1 %32 How to Replace Sequins or Beads: passo 3, imagem 2 %32 How to Replace Sequins or Beads: passo 3, imagem 3 %32
    • Make an anchor stitch where the missing item needs to be.
  4. How to Replace Sequins or Beads: passo 4, imagem 1 %32 How to Replace Sequins or Beads: passo 4, imagem 2 %32
    • Put the missing sequin or bead through the thread.
  5. How to Replace Sequins or Beads: passo 5, imagem 1 %32
    • Slide the sequin or bead down the thread to the anchor stitch.
  6. How to Replace Sequins or Beads: passo 6, imagem 1 %32
    • Make a straight stitch over one side of the sequin or bead into the fabric.
  7. How to Replace Sequins or Beads: passo 7, imagem 1 %32
    • Put the needle through the back of the last stitch without puncturing the fabric.
  8. How to Replace Sequins or Beads: passo 8, imagem 1 %32
    • Pull the thread through enough to make a circle.
  9. How to Replace Sequins or Beads: passo 9, imagem 1 %32 How to Replace Sequins or Beads: passo 9, imagem 2 %32
    • Pull the thread through the circle to make a knot.
Conclusão
Repeat the procedure for all missing sequins/beads/buttons on the clothing.
Garrett Wartelle
Membro desde: 10/25/21
169 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 19
Duração total: 1,184
