Ir para o conteúdo principal
How to Replace Magliner Hand Truck Wheels
O que você precisa
  1. How to Replace Magliner Hand Truck Wheels, Replacement of Magliner Hand Truck Wheel: passo 1, imagem 1 %32 How to Replace Magliner Hand Truck Wheels, Replacement of Magliner Hand Truck Wheel: passo 1, imagem 2 %32 How to Replace Magliner Hand Truck Wheels, Replacement of Magliner Hand Truck Wheel: passo 1, imagem 3 %32
    • Straighten the bottom of the cotter pin with the pliers to slide out the cotter pin.
  2. How to Replace Magliner Hand Truck Wheels: passo 2, imagem 1 %32 How to Replace Magliner Hand Truck Wheels: passo 2, imagem 2 %32
    • Remove the stainless steel washer(s) before pulling out the wheel(s) from the spindle.
  3. How to Replace Magliner Hand Truck Wheels: passo 3, imagem 1 %32 How to Replace Magliner Hand Truck Wheels: passo 3, imagem 2 %32
    • Pull the wheel in the opposite direction and slide out the old wheel(s).
  4. How to Replace Magliner Hand Truck Wheels: passo 4, imagem 1 %32 How to Replace Magliner Hand Truck Wheels: passo 4, imagem 2 %32 How to Replace Magliner Hand Truck Wheels: passo 4, imagem 3 %32
    • Insert the new wheel into the wheel spindle.
    • There should be about half an inch left of the wheel spindle.
  5. How to Replace Magliner Hand Truck Wheels: passo 5, imagem 1 %32 How to Replace Magliner Hand Truck Wheels: passo 5, imagem 2 %32 How to Replace Magliner Hand Truck Wheels: passo 5, imagem 3 %32
    • Replace the old washer(s) and add a new washer(s) on top of the wheel.
  6. How to Replace Magliner Hand Truck Wheels: passo 6, imagem 1 %32 How to Replace Magliner Hand Truck Wheels: passo 6, imagem 2 %32 How to Replace Magliner Hand Truck Wheels: passo 6, imagem 3 %32
    • Replace the old cotter pin with a new cotter pin and slide it back into the hole at the edge of the wheel spindle.
  7. How to Replace Magliner Hand Truck Wheels: passo 7, imagem 1 %32 How to Replace Magliner Hand Truck Wheels: passo 7, imagem 2 %32 How to Replace Magliner Hand Truck Wheels: passo 7, imagem 3 %32
    • Spread the right end of the new cotter pin(s) slightly outwards with the pliers.
    • This will create almost an L shape and secure the cotter pin in place.
Conclusão
Melissa Gaspar
Membro desde: 03/25/24
145 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 18
Duração total: 72
