Introdução
If your Magliner hand truck struggles to navigate smoothly due to worn-out wheels, this guide is here to help. Worn wheels on a hand truck can significantly impede functionality, especially in rough or greasy environments.
When a hand truck's wheels show signs of wear and tear, addressing the issue promptly is crucial to ensure smooth operation. This guide will walk you through replacing and adjusting worn Magliner hand truck wheels and restoring your equipment to optimal performance.
O que você precisa
Straighten the bottom of the cotter pin with the pliers to slide out the cotter pin.
