Ir para o conteúdo principal
How to Replace KBD67 Lite R3 Keyboard Switch Spring
O que você precisa
  1. How to Replace KBD67 Lite R3 Keyboard Switch Spring, Switch Spring: passo 1, imagem 1 %32 How to Replace KBD67 Lite R3 Keyboard Switch Spring, Switch Spring: passo 1, imagem 2 %32
    • Align the keycap puller to the keycap.
    • Gently pull vertically on the keycap to remove it, exposing the key switch.
  2. How to Replace KBD67 Lite R3 Keyboard Switch Spring: passo 2, imagem 1 %32 How to Replace KBD67 Lite R3 Keyboard Switch Spring: passo 2, imagem 2 %32 How to Replace KBD67 Lite R3 Keyboard Switch Spring: passo 2, imagem 3 %32
    • Align the key switch puller with the key switch that you're removing.
    • Pull the key switch out of the keyboard.
  3. How to Replace KBD67 Lite R3 Keyboard Switch Spring: passo 3, imagem 1 %32 How to Replace KBD67 Lite R3 Keyboard Switch Spring: passo 3, imagem 2 %32 How to Replace KBD67 Lite R3 Keyboard Switch Spring: passo 3, imagem 3 %32
    • Locate the side of the switch that has latches.
    • Place the side of the switch with latches on top of the key switch opener legs.
    • Apply gentle force pushing the switch down on the switch opener to open up the switch.
  4. How to Replace KBD67 Lite R3 Keyboard Switch Spring: passo 4, imagem 1 %32 How to Replace KBD67 Lite R3 Keyboard Switch Spring: passo 4, imagem 2 %32
    • Remove the top housing and stem to reveal the switch spring.
    • Remove the switch spring and proceed to replace it with another spring of your choice.
  5. How to Replace KBD67 Lite R3 Keyboard Switch Spring: passo 5, imagem 1 %32 How to Replace KBD67 Lite R3 Keyboard Switch Spring: passo 5, imagem 2 %32 How to Replace KBD67 Lite R3 Keyboard Switch Spring: passo 5, imagem 3 %32
    • Locate the side of the switch that has legs, then place the switch on top of the spring. with the legs facing the metal plate.
    • Push the top and bottom housing together to assemble the switch.
    • Do not do this on the switch opener. The switch opener was used for photography purposes.
  6. How to Replace KBD67 Lite R3 Keyboard Switch Spring: passo 6, imagem 1 %32 How to Replace KBD67 Lite R3 Keyboard Switch Spring: passo 6, imagem 2 %32 How to Replace KBD67 Lite R3 Keyboard Switch Spring: passo 6, imagem 3 %32
    • Locate the switch pin holes on your keyboard.
    • Locate the pins on your key switch and line it up with the keyboard pin holes.
    • Apply gentle force pushing down until it clicks onto place.
  7. How to Replace KBD67 Lite R3 Keyboard Switch Spring: passo 7, imagem 1 %32
    • Put the key cap back onto the switch.
    • Test the keyboard input and ensure that everything is functioning correctly.
Conclusão
Frank Loi
Membro desde: 07/04/22
145 Reputação
Autoria de 1 guia
Equipe
1Comentário do guia
Frank you did an amazing job on this one. I always wondered how to replace a keyboard key and finally you provided a perfect guide. Your introduction covers everything one needs to know including the parts required - thank you for the where to buy links. Talking about the guide it's clear and precise - all steps are documented well with those amazing parts focused pictures. Language is easy to read and understand. After reading your guide I feel more confident now to replace the key or the spring within.
Krushi Patel - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 53
Ao todo: 1,267
