Ir para o conteúdo principal
How to Replace Damaged Clarinet Cork With Foam
O que você precisa
  1. How to Replace Damaged Clarinet Cork With Foam, How to Replace Damaged Clarinet Cork With Foam: passo 1, imagem 1 %32
    • Take your clarinet and identify where the cork is damaged and assess the extent of the damaged cork.
  2. How to Replace Damaged Clarinet Cork With Foam: passo 2, imagem 1 %32
    • With a small razor, start cutting the cork by creating a line vertically and horizontally.
  3. How to Replace Damaged Clarinet Cork With Foam: passo 3, imagem 1 %32 How to Replace Damaged Clarinet Cork With Foam: passo 3, imagem 2 %32
    • After cutting the cork vertically and horizontally, try removing as much cork as possible.
  4. How to Replace Damaged Clarinet Cork With Foam: passo 4, imagem 1 %32 How to Replace Damaged Clarinet Cork With Foam: passo 4, imagem 2 %32
    • With the small razor used to cut the cork, cut a piece of foam.
    • The size will depend on what part of the clarinet you are fixing.
    • Use a glue gun to bond the foam to the clarinet tenon.
  5. How to Replace Damaged Clarinet Cork With Foam: passo 5, imagem 1 %32
    • After gluing the piece of foam, let it dry.
    • Assemble the clarinet until it fits completely.
  6. How to Replace Damaged Clarinet Cork With Foam: passo 6, imagem 1 %32
    • Finally, the clarinet is fixed, and it will function properly until you are able to replace the cork.
Conclusão
After complete all the steps the clarinet is ready and the musician may continue performing with it. A simple repair like this allows the musician to order clarinet parts that’ll take awhile to arrive.
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 20
Duração total: 218
