Ir para o conteúdo principal
How to Replace Concealed Cabinet Hinges
O que você precisa
  1. How to Replace Concealed Cabinet Hinges, Hinge: passo 1, imagem 1 %32 How to Replace Concealed Cabinet Hinges, Hinge: passo 1, imagem 2 %32 How to Replace Concealed Cabinet Hinges, Hinge: passo 1, imagem 3 %32
    • Remove the screws that are attached to the cabinet door.
    • Unscrew the top and bottom hinges even if you are only replacing one hinge.
    • Remove the cabinet door from the hinge.
    • You may need to wiggle or pry the door off.
  2. How to Replace Concealed Cabinet Hinges: passo 2, imagem 1 %32 How to Replace Concealed Cabinet Hinges: passo 2, imagem 2 %32
    • Remove the screws that go into the cabinet frame from the hinge, then remove the hinge.
    • Only the hinge being replaced needs to be removed.
  3. How to Replace Concealed Cabinet Hinges: passo 3, imagem 1 %32 How to Replace Concealed Cabinet Hinges: passo 3, imagem 2 %32 How to Replace Concealed Cabinet Hinges: passo 3, imagem 3 %32
    • Insert the new hinge into the cabinet door's pre-cut hole.
    • Attach the hinge with the provided screws.
    • To avoid striping the screws, do not over tighten.
  4. How to Replace Concealed Cabinet Hinges: passo 4, imagem 1 %32
    • Reattach the cabinet door to the cabinet frame.
    • Do not tighten the screws all the way. You will need to align the door later.
    • You may need a friend to hold the door while you screw it back into place.
  5. How to Replace Concealed Cabinet Hinges: passo 5, imagem 1 %32 How to Replace Concealed Cabinet Hinges: passo 5, imagem 2 %32
    • Lift or lower the cabinet door to align the hinges with its original location.
    • Changes in wood stain can serve as a useful alignment guide.
    • Tighten all the screws.
  6. How to Replace Concealed Cabinet Hinges: passo 6, imagem 1 %32 How to Replace Concealed Cabinet Hinges: passo 6, imagem 2 %32 How to Replace Concealed Cabinet Hinges: passo 6, imagem 3 %32
    • Use this step to adjust the amount of space between the cabinet door and the cabinet frame.
    • Loosen the adjustment screws, but do not remove them.
    • Slide the cabinet door to your desired position.
    • Tighten the screws.
  7. How to Replace Concealed Cabinet Hinges: passo 7, imagem 1 %32
    • Use this step if your cabinet door closes too hard or does not completely close.
    • Tighten this screw to keep the cabinet door from closing too hard. Loosen the screw to allow the cabinet door to close completely.
    • Do not completely remove this screw.
Linha de Chegada
4 outras pessoas executaram este guia.
Naomi Frazier
Membro desde: 04/28/17
171 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team S4-G4, Cole Spring 2017 Membro de UC Davis, Team S4-G4, Cole Spring 2017
UCD-COLE-S17S4G4
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 24
Últimos 30 dias: 94
Duração total: 28,808
