Ir para o conteúdo principal
How to Replace Cabinet Door Bumpers
O que você precisa
  1. How to Replace Cabinet Door Bumpers, Cabinet Door Bumpers: passo 1, imagem 1 %32 How to Replace Cabinet Door Bumpers, Cabinet Door Bumpers: passo 1, imagem 2 %32 How to Replace Cabinet Door Bumpers, Cabinet Door Bumpers: passo 1, imagem 3 %32
    • Open the cabinet door to access the existing bumpers.
  2. How to Replace Cabinet Door Bumpers: passo 2, imagem 1 %32 How to Replace Cabinet Door Bumpers: passo 2, imagem 2 %32 How to Replace Cabinet Door Bumpers: passo 2, imagem 3 %32
    • Use a plastic scraper to remove the existing bumpers.
    • Using a metal scraper or excessive force could scratch your cabinets.
  3. How to Replace Cabinet Door Bumpers: passo 3, imagem 1 %32 How to Replace Cabinet Door Bumpers: passo 3, imagem 2 %32 How to Replace Cabinet Door Bumpers: passo 3, imagem 3 %32
    • Apply a small amount of adhesive remover to a paper towel.
    • Rub the area where the old bumpers were located to remove any sticky residue.
    • Use WD-40 or rubbing alcohol to remove sticky residue from stainless steel cabinets.
  4. How to Replace Cabinet Door Bumpers: passo 4, imagem 1 %32 How to Replace Cabinet Door Bumpers: passo 4, imagem 2 %32 How to Replace Cabinet Door Bumpers: passo 4, imagem 3 %32
    • Clean the area with a damp cloth and mild soap to remove any remaining adhesive remover or residue.
  5. How to Replace Cabinet Door Bumpers: passo 5, imagem 1 %32
    • Let the area dry completely.
  6. How to Replace Cabinet Door Bumpers: passo 6, imagem 1 %32 How to Replace Cabinet Door Bumpers: passo 6, imagem 2 %32 How to Replace Cabinet Door Bumpers: passo 6, imagem 3 %32
    • Peel off the backing from the adhesive side of the new bumpers.
    • Place the new bumper onto the clean, dry surface where the old bumpers used to be.
    • Press the bumper onto the cabinet to secure the adhesive.
  7. How to Replace Cabinet Door Bumpers: passo 7, imagem 1 %32 How to Replace Cabinet Door Bumpers: passo 7, imagem 2 %32 How to Replace Cabinet Door Bumpers: passo 7, imagem 3 %32
    • Open and close the cabinet doors a few times to ensure that the new bumpers are securely in place and effectively cushioning the doors.
Linha de Chegada
Brenda M
Membro desde: 06/23/24
145 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 53
Ao todo: 764
