Ir para o conteúdo principal
How to Replace Buttons on a 2021 Samsung Smart TV Remote BN59-01357F
O que você precisa
  1. How to Replace Buttons on a 2021 Samsung Smart TV Remote BN59-01357F, Buttons: passo 1, imagem 1 %32 How to Replace Buttons on a 2021 Samsung Smart TV Remote BN59-01357F, Buttons: passo 1, imagem 2 %32 How to Replace Buttons on a 2021 Samsung Smart TV Remote BN59-01357F, Buttons: passo 1, imagem 3 %32
    • Clean the remote of any dirt between the circuit and buttons.
    • Slide the back cover off and remove the batteries to ensure there is no power.
  2. How to Replace Buttons on a 2021 Samsung Smart TV Remote BN59-01357F: passo 2, imagem 1 %32 How to Replace Buttons on a 2021 Samsung Smart TV Remote BN59-01357F: passo 2, imagem 2 %32 How to Replace Buttons on a 2021 Samsung Smart TV Remote BN59-01357F: passo 2, imagem 3 %32
    • Using your hand or a pry tool to separate the front cover from the remote.
    • The remote is held by clips and this process requires to be delicate with the remote.
    • This will expose the buttons and the circuit board.
  3. How to Replace Buttons on a 2021 Samsung Smart TV Remote BN59-01357F: passo 3, imagem 1 %32 How to Replace Buttons on a 2021 Samsung Smart TV Remote BN59-01357F: passo 3, imagem 2 %32 How to Replace Buttons on a 2021 Samsung Smart TV Remote BN59-01357F: passo 3, imagem 3 %32
    • After disassembly, place the front cover onto the surface and separate the buttons that need to be replaced from the circuit board.
  4. How to Replace Buttons on a 2021 Samsung Smart TV Remote BN59-01357F: passo 4, imagem 1 %32 How to Replace Buttons on a 2021 Samsung Smart TV Remote BN59-01357F: passo 4, imagem 2 %32
    • Take the circuit board out of the remote assembly and prepare for some quick cleaning.
  5. How to Replace Buttons on a 2021 Samsung Smart TV Remote BN59-01357F: passo 5, imagem 1 %32 How to Replace Buttons on a 2021 Samsung Smart TV Remote BN59-01357F: passo 5, imagem 2 %32 How to Replace Buttons on a 2021 Samsung Smart TV Remote BN59-01357F: passo 5, imagem 3 %32
    • Use a toothbrush to clean out the circuit board and the internals of the remote.
  6. How to Replace Buttons on a 2021 Samsung Smart TV Remote BN59-01357F: passo 6, imagem 1 %32 How to Replace Buttons on a 2021 Samsung Smart TV Remote BN59-01357F: passo 6, imagem 2 %32 How to Replace Buttons on a 2021 Samsung Smart TV Remote BN59-01357F: passo 6, imagem 3 %32
    • Prepare the new buttons to be placed on the circuit board.
    • Place the circuit board back into the remote assembly.
    • Place the new buttons on top of the circuit board.
  7. How to Replace Buttons on a 2021 Samsung Smart TV Remote BN59-01357F: passo 7, imagem 1 %32 How to Replace Buttons on a 2021 Samsung Smart TV Remote BN59-01357F: passo 7, imagem 2 %32 How to Replace Buttons on a 2021 Samsung Smart TV Remote BN59-01357F: passo 7, imagem 3 %32
    • Place the front cover on top of the new buttons and align the front cover with the clips on the main remote board.
    • NOTE When you hear a small click, it means it's properly attached.
  8. How to Replace Buttons on a 2021 Samsung Smart TV Remote BN59-01357F: passo 8, imagem 1 %32 How to Replace Buttons on a 2021 Samsung Smart TV Remote BN59-01357F: passo 8, imagem 2 %32 How to Replace Buttons on a 2021 Samsung Smart TV Remote BN59-01357F: passo 8, imagem 3 %32
    • Put the batteries back on to the remote and slide the rear cover of the remote on.
    • Test for all button functionalities to ensure the repair is done sufficiently.
    • The red light on top of the remote will blink every time a button is functioning.
Conclusão
This repair guide provides both disassembly and reassembly methods. After the fix ensure the remote is still functioning by doing user testing.
Saijith Charathchandra
Membro desde: 01/22/21
157 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 29
Últimos 30 dias: 141
Duração total: 1,452
