Ir para o conteúdo principal
How to Replace Basic Bag Lining
O que você precisa
  1. How to Replace Basic Bag Lining, Bag Lining: passo 1, imagem 1 %32
    • Assess the old bag lining you will be replacing.
    • Consider color, material, and amount of fabric needed for the new lining.
  2. How to Replace Basic Bag Lining: passo 2, imagem 1 %32 How to Replace Basic Bag Lining: passo 2, imagem 2 %32 How to Replace Basic Bag Lining: passo 2, imagem 3 %32
    • At the seams, use your hands or sewing to carefully rip or cut out old bag lining.
  3. How to Replace Basic Bag Lining: passo 3, imagem 1 %32
    • Lay out old bag lining on fabric and measure out the size of the new bag lining, adding an extra 2 cm on each side.
  4. How to Replace Basic Bag Lining: passo 4, imagem 1 %32 How to Replace Basic Bag Lining: passo 4, imagem 2 %32
    • Fold new fabric in half to create one closed end for the bag lining.
    • Cut out bag lining based on measurements from previous step.
  5. How to Replace Basic Bag Lining: passo 5, imagem 1 %32
    • Stitch the two sides of fabric adjacent to the folded side to create a rectangle with one opening.
    • You can stitch by hand or use a sewing machine.
    • Use stitches small and tight enough to ensure new lining remains intact.
    • Finish stitching 2 cm from the end of the open side.
  6. How to Replace Basic Bag Lining: passo 6, imagem 1 %32
    • Fold over extra 2 cm from the opening of the new bag lining outward to hide the raw edge of the fabric.
    • With a needle suitable for sewing through your bag material, attach the bag lining with a straight running stitch around the mouth of the bag.
    • See the article How to Work a Running Stitch from The Spruce Crafts to learn how to do a running stitch.
Linha de Chegada
Ijada Nguyen
Membro desde: 01/26/23
133 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 1-1, Morris Winter 2023 Membro de UC Davis, Team 1-1, Morris Winter 2023
UCD-MORRIS-W23S1G1
Membros da 2
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 85
Duração total: 949
