Ir para o conteúdo principal
How to Repair the Sparker on a Merlion Mini Torch
O que você precisa
  1. How to Repair the Sparker on a Merlion Mini Torch, How to Repair the Sparker on a Merlion Mini Torch: passo 1, imagem 1 %32 How to Repair the Sparker on a Merlion Mini Torch, How to Repair the Sparker on a Merlion Mini Torch: passo 1, imagem 2 %32 How to Repair the Sparker on a Merlion Mini Torch, How to Repair the Sparker on a Merlion Mini Torch: passo 1, imagem 3 %32
    • Use the screwdriver to remove all the 1.2 mm Phillips #1 countersunk screws from the torch.
  2. How to Repair the Sparker on a Merlion Mini Torch: passo 2, imagem 1 %32 How to Repair the Sparker on a Merlion Mini Torch: passo 2, imagem 2 %32
    • Open up the torch.
    • Set aside the empty side of the torch.
  3. How to Repair the Sparker on a Merlion Mini Torch: passo 3, imagem 1 %32 How to Repair the Sparker on a Merlion Mini Torch: passo 3, imagem 2 %32 How to Repair the Sparker on a Merlion Mini Torch: passo 3, imagem 3 %32
    • Pull the handle down as if you were to use the torch.
    • You will see one of the parts inside spark. This is the sparker.
    • Now gently remove the handle and set it aside.
  4. How to Repair the Sparker on a Merlion Mini Torch: passo 4, imagem 1 %32 How to Repair the Sparker on a Merlion Mini Torch: passo 4, imagem 2 %32
    • Grab your pliers and GENTLY tug the sparker towards the Merlion head until it is extended about a centimeter.
  5. How to Repair the Sparker on a Merlion Mini Torch: passo 5, imagem 1 %32 How to Repair the Sparker on a Merlion Mini Torch: passo 5, imagem 2 %32
    • Gently bend the sparker until it is positioned near the opening of the Merlion's mouth.
  6. How to Repair the Sparker on a Merlion Mini Torch: passo 6, imagem 1 %32 How to Repair the Sparker on a Merlion Mini Torch: passo 6, imagem 2 %32 How to Repair the Sparker on a Merlion Mini Torch: passo 6, imagem 3 %32
    • Grab the tube and gently bend it so it faces the opening of the Merlion's mouth.
    • Put the handle back on the torch.
  7. How to Repair the Sparker on a Merlion Mini Torch: passo 7, imagem 1 %32 How to Repair the Sparker on a Merlion Mini Torch: passo 7, imagem 2 %32 How to Repair the Sparker on a Merlion Mini Torch: passo 7, imagem 3 %32
    • Take the empty half of the torch and place it over the other half.
  8. How to Repair the Sparker on a Merlion Mini Torch: passo 8, imagem 1 %32 How to Repair the Sparker on a Merlion Mini Torch: passo 8, imagem 2 %32 How to Repair the Sparker on a Merlion Mini Torch: passo 8, imagem 3 %32
    • Use the screwdriver to put the screws back in the torch.
  9. How to Repair the Sparker on a Merlion Mini Torch: passo 9, imagem 1 %32 How to Repair the Sparker on a Merlion Mini Torch: passo 9, imagem 2 %32
    • Hold the torch upside down and position the butane above the torch's hole.
    • Gently press down for five seconds.
Conclusão
Congrats! Now you can use your Merlion torch again.
3 outras pessoas executaram este guia.
Neel Kogali
Membro desde: 09/29/15
200 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 14-3, Green Fall 2015 Membro de Cal Poly, Team 14-3, Green Fall 2015
CPSU-GREEN-F15S14G3
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 20
Duração total: 7,614
