Ir para o conteúdo principal
How to Repair the Jump Ring on a Mask Holder
O que você precisa
  1. How to Repair the Jump Ring on a Mask Holder, How to Repair the Jump Ring on a Mask Holder: passo 1, imagem 1 %32
    • Remove the broken or opened jump ring from your mask holder.
  2. How to Repair the Jump Ring on a Mask Holder: passo 2, imagem 1 %32
    • Hold needle nose pliers with one hand and the jump ring in the other.
    • Make sure you have good light so you can see clearly.
  3. How to Repair the Jump Ring on a Mask Holder: passo 3, imagem 1 %32 How to Repair the Jump Ring on a Mask Holder: passo 3, imagem 2 %32
    • Use the pliers to open the jump ring carefully.
  4. How to Repair the Jump Ring on a Mask Holder: passo 4, imagem 1 %32
    • Reattach the chain to the jump ring.
  5. How to Repair the Jump Ring on a Mask Holder: passo 5, imagem 1 %32
    • Use the pliers to close the jump ring.
  6. How to Repair the Jump Ring on a Mask Holder: passo 6, imagem 1 %32 How to Repair the Jump Ring on a Mask Holder: passo 6, imagem 2 %32
    • Make sure the ring is closed tightly so the mask holder stays secure.
Linha de Chegada
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Ao todo: 459
