Ir para o conteúdo principal
How to Repair the Broken End of a Garden Hose
O que você precisa
  1. How to Repair the Broken End of a Garden Hose, How to Repair the Broken End of a Garden Hose: passo 1, imagem 1 %32
    • Measure the diameter of the inside of the original hose.
  2. How to Repair the Broken End of a Garden Hose: passo 2, imagem 1 %32
    • Choose the right size of the hose end.
    • Know the difference between the male and female ends (the featured end is female).
    • Hoses typically come in sizes 5/8", 3/4", and 1/2".
  3. How to Repair the Broken End of a Garden Hose: passo 3, imagem 1 %32
    • Remove the original broken end by using a utility knife to cut 2-3 inches from the hose.
    • Place the hose on a flat surface such as a workbench, and perform a smooth, straight cut.
  4. How to Repair the Broken End of a Garden Hose: passo 4, imagem 1 %32
    • Remove the fitting.
  5. How to Repair the Broken End of a Garden Hose: passo 5, imagem 1 %32 How to Repair the Broken End of a Garden Hose: passo 5, imagem 2 %32 How to Repair the Broken End of a Garden Hose: passo 5, imagem 3 %32
    • Attach the new fitting.
    • Slide the clamp onto the hose.
    • Insert the new fitting.
    • Soak the hose in warm water or let it sit in the sun to make it more pliable.
  6. How to Repair the Broken End of a Garden Hose: passo 6, imagem 1 %32
    • Tighten the clamp with a screwdriver.
Conclusão
Test your new and improved hose by turning on the water and watching for leaks.
3 outras pessoas executaram este guia.
Um comentário
Warm water is a good idea.
pwkoughan - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 22
Últimos 30 dias: 87
Duração total: 5,999
