Ir para o conteúdo principal
How to Repair an Elastic Loop on a Blouse
O que você precisa
  1. How to Repair an Elastic Loop on a Blouse, How to Repair an Elastic Loop on a Blouse: passo 1, imagem 1 %32
    • Place the broken elastic loop back in its original position on the blouse.
  2. How to Repair an Elastic Loop on a Blouse: passo 2, imagem 1 %32
    • Double thread the needle.
    • Pass the needle through the base of the elastic loop.
  3. How to Repair an Elastic Loop on a Blouse: passo 3, imagem 1 %32 How to Repair an Elastic Loop on a Blouse: passo 3, imagem 2 %32
    • Pass the needle through the stitch line where the elastic loop was originally secured, then back through the base of the elastic loop, at least 6-7 times.
    • Don't pull the thread tight; leave a loop to tie off the thread.
    • Insert your needle through the loops, then pull the thread tight.
  4. How to Repair an Elastic Loop on a Blouse: passo 4, imagem 1 %32
    • Simply cut the thread connected to the needle, and then any dangling threads.
Conclusão
Enjoy your revitalized garment!
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 51
Ao todo: 4,446
