Ir para o conteúdo principal
How to Repair a Whiteboard Frame
O que você precisa
  1. How to Repair a Whiteboard Frame, How to Repair a Whiteboard Frame: passo 1, imagem 1 %32
    • Gather all your tools which are listed in the tool area.
  2. How to Repair a Whiteboard Frame: passo 2, imagem 1 %32 How to Repair a Whiteboard Frame: passo 2, imagem 2 %32
    • Start by applying Goo Gone onto a paper towel to remove any sticky residue from the outside of the whiteboard.
  3. How to Repair a Whiteboard Frame: passo 3, imagem 1 %32 How to Repair a Whiteboard Frame: passo 3, imagem 2 %32 How to Repair a Whiteboard Frame: passo 3, imagem 3 %32
    • Clean the surface using a multipurpose cleaner safe for wood to remove any remaining residue and debris
  4. How to Repair a Whiteboard Frame: passo 4, imagem 1 %32 How to Repair a Whiteboard Frame: passo 4, imagem 2 %32 How to Repair a Whiteboard Frame: passo 4, imagem 3 %32
    • Apply an even amount of glue to each piece, then place them into position and wipe off any excess glue
  5. How to Repair a Whiteboard Frame: passo 5, imagem 1 %32
    • Hold all the pieces together for a minute to allow the glue to set firmly.
  6. How to Repair a Whiteboard Frame: passo 6, imagem 1 %32 How to Repair a Whiteboard Frame: passo 6, imagem 2 %32 How to Repair a Whiteboard Frame: passo 6, imagem 3 %32
    • Secure the pieces with clamps at the corners and wait for 24 hours to let the glue dry.
  7. How to Repair a Whiteboard Frame: passo 7, imagem 1 %32 How to Repair a Whiteboard Frame: passo 7, imagem 2 %32
    • After 24 Hours, remove the clamps carefully.
  8. How to Repair a Whiteboard Frame: passo 8, imagem 1 %32 How to Repair a Whiteboard Frame: passo 8, imagem 2 %32
    • After 24 hours, remove the clamps and sand down any rough corners if necessary.
  9. How to Repair a Whiteboard Frame: passo 9, imagem 1 %32 How to Repair a Whiteboard Frame: passo 9, imagem 2 %32
    • Touch up any areas on the whiteboard using black paint where needed.
  10. How to Repair a Whiteboard Frame: passo 10, imagem 1 %32
    • Congratulations! Your whiteboard is now fixed and ready to use.
Conclusão
Jelena Drca
Membro desde: 02/02/24
181 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 3-9, Andersen Winter 2024 Membro de UC Davis, Team 3-9, Andersen Winter 2024
UCD-ANDERSEN-W24S3G9
3 Membros
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 19
Últimos 30 dias: 82
Ao todo: 849
